2011 Nissan Titan Alarm/Remote Start Wiring
lurch228
Silver - Posts: 1,338
Posted: July 30, 2016 at 9:31 PM / IP Logged
MAKE : NISSAN | MODEL : TITAN | YEAR : 2011
12volts
      green (40A)
      ignition switch, white 6 pin plug, pin 3
Starter      brown      +      ignition switch, white 6 pin plug, pin 2
Ignition      BLACK/ red      +      ignition switch, white 6 pin plug, pin 1
Power Lock      (use factory alarm arm)
Power Unlock      (use factory alarm disarm)
Lock Motor      purple      5 wire      BCM right of steering column, black 15 pin plug, pin 10
Unlock Motor      green      5 wire      BCM right of steering column, black 15 pin plug, pin 4
Disarm Defeat      GREEN/ YELLOW      5 wire      BCM right of steering column, black 15 pin plug, pin 11
Parking Lights+      RED / blue      +      electric brake pre-wiring left of strg column, white 6 pin plug, pin 4
Parking Lights-      N/A
Hazards      WHITE/ black      -      BCM right of steering column, white 40 pin plug, pin 29
Turn Signal(L)      GREEN/ black      +      BCM right of steering column, black 15 pin plug, pin 5
Turn Signal(R)      GREEN/ YELLOW      +      BCM right of steering column, black 15 pin plug, pin 6
Door Trigger      lt. blue      -      BCM right of steering column, white 15 pin plug, pin 7
Dome Supervision      blue (dome lamps); RED / white (step lamps)      -      BCM right of steering column, black 15 pin plug, pins 8, 7
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      blue (driver door key lock)      -      power window main switch, white 16 pin plug, pin 6 or 4
Factory Alarm Disarm      red (driver door key unlock)      double -      power window main switch, white 16 pin plug, pin 7 or 6
Disarm No Unlock      (see factory alarm disarm)
Tachometer      NOT white      ac      any fuel injector
Horn Trigger      RED / white      -      horn switch, gray 8 pin plug, pin 2
Memory Seat 1      lt. GREEN/ black      -      driver kick, brown 24 pin plug, pin 5
Memory Seat 2      pink/blue      -      driver kick, brown 24 pin plug, pin 1
Memory Seat 3      N/A      -
* The logo is registered trade mark of Nissan Corporate.
