2015 f150 alarm, hood pin wire
eddieschopshop
Member - Posts: 7
Posted: January 31, 2017 at 7:03 AM / IP Logged Link to Post Post Reply Quote eddieschopshop
I would like to install a shock sensor on my 2015 f150. what i would like to find out is where the hood pin is located physically in under hood or the wire color and location inside cab for hood pin.
thanks in advance.
eddie
eddieschopshop
Member - Posts: 7
Posted: February 01, 2017 at 6:00 AM / IP Logged Link to Post Post Reply Quote eddieschopshop
**UPDATE**
I found out last night that my 2015 f150 does not have a hood pin for a signal. what it does use is a micro switch by the hood latch that will sense when hood is released. wasn't able to test which wire I will need to cut and split cause got kind of late but I will if I have a chance this afternoon.
eddieschopshop
Member - Posts: 7
Posted: February 02, 2017 at 10:05 AM / IP Logged Link to Post Post Reply Quote eddieschopshop
**UPDATE 2**
blue/orange is the wire that will need to be spilt to create signal in/out for relay.
this is for the people that want to add shock sensor to factory keyless entry. im sure same concept will work for any car/truck with factory keyless entry.
