2011 Subaru Outback w/ HK System Non-Nav
theglassprizon
Posted: May 16, 2017 at 9:28 PM / IP Logged
The subaru section has everything BUT this one. I think the HU is sending low level to the HK amp under the seat. was wondering if i can make a harness and go to my audison bit ten or just strait to my PDX V9?
dont mistake genius for lack of talent.
tonanzith
Gold - Posts: 603
Posted: May 21, 2017 at 10:32 PM / IP Logged
Subaru Outback - North America     DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     white (40A)     +     ignition switch, white 6 pin plug, pin 3
Starter     white/blue     +     ignition switch, white 6 pin plug, pin 2
Second Starter     white/green or white/orange     +     ignition switch, white 6 pin plug, pin 6
Ignition     green     +     ignition switch, white 6 pin plug, pin 1
Accessory     blue     +     ignition switch, white 6 pin plug, pin 4
Second Accessory     yellow     +     ignition switch, white 6 pin plug, pin 5
Keysense     black/white     +     BIU right of steering column, white 34 pin plug (A), pin 4
CAN Bus High     red     data     BIU right of steering column, white 35 pin plug (B), pin 20
CAN Bus Low     blue     data     BIU right of steering column, white 35 pin plug (B), pin 28
IMMO Data     white/blue     data     BIU right of steering column, white 34 pin plug (A), pin 31
Security Light     brown/red     -     BIU right of steering column, white 31 pin plug (D), pin 26
Door Lock Data     yellow (keyless data)     data     BIU right of steering column, white 31 pin plug (D), pin 11
Power Lock     brown/white     -     BIU right of steering column, white 35 pin plug (C), pin 9
Power Unlock     brown/black     -     BIU right of steering column, white 35 pin plug (C), pin 20
Lock Motor     lt. green/yellow     5 wire     BIU right of steering column, white 31 pin plug (D), pin 2
Driver Unlock Motor     lt. green     5 wire     BIU right of steering column, white 31 pin plug (D), pin 4
Passenger Unlock Motor     red/green     5 wire     BIU right of steering column, white 31 pin plug (D), pin 3
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (transponder, ignition, and keysense)
Parking Lights (+)     black/blue     +     dash fuse box, white 20 pin plug, pin 10
Parking Lights (-)     black/white     -     BIU right of steering column, white 35 pin plug (B), pin 17
Hazards     green     -     BIU right of steering column, white 31 pin plug (D), pin 18
Turn Signal (Left)     blue     +     dash fuse box, white 20 pin plug, pin 20
Turn Signal (Right)     red/green     +     dash fuse box, white 20 pin plug, pin 3
Headlight     pink/white     -     BIU right of steering column, white 35 pin plug (B), pin 34
AutoLights     blue (interrupt to turn off)     -     BIU right of steering column, white 35 pin plug (B), pin 16
Reverse Light     brown/yellow     +     driver kick, white 16 pin plug, pin 7
Left Front Door Trigger     blue/white     -     BIU right of steering column, white 35 pin plug (C), pin 14
Right Front Door Trigger     blue/orange     -     BIU right of steering column, white 35 pin plug (C), pin 13
Left Rear Door Trigger     yellow/red     -     BIU right of steering column, white 35 pin plug (C), pin 24
Right Rear Door Trigger     white/red     -     BIU right of steering column, white 35 pin plug (C), pin 25
Dome Light     brown     -     BIU right of steering column, white 35 pin plug (C), pin 4
Trunk/Hatch Pin     lt. green/black     -     BIU right of steering column, white 35 pin plug (C), pin 33
Hood Pin     yellow/black (with remote start only)     -     hood switch or Remote Start Module behind dash fuse box, white 4 pin plug, pin 4
Trunk/Hatch Release     red (release switch, Legacy) (rear handle switch, Outback)     -     BIU right of steering column, white 35 pin plug (C), pin 10
Trunk Release Motor     white/black     5 wire     BIU right of steering column, white 31 pin plug (D), pin 7
Tachometer     red/white to white/green     ac     instrument cluster, white 40 pin plug, pin 30 or ECM behind glove box, white 35 pin plug (B), pin 15
Neutral Safety     green/black (M/T)     -     ECM behind glove box, white 35 pin plug (C), pin 35
Clutch Pedal     black/blue     -     clutch switch, white 5 pin plug, pin 2
Fuel Pump     red/black     +     passenger kick, white 11 pin plug, pin 2
Rear Defroster     purple/green     - latched     BIU right of steering column, white 34 pin plug (A), pin 26
Mirror Defroster     (mirror same as rear defroster); green/black (wiper deicer)     - latched     BIU right of steering column, white 31 pin plug (D), pin 9
Left Front Heated Seat     lt. green (LO)     5 wire     left seat heater switch, white 6 pin plug, pin 5
Right Front Heated Seat     white (LO)     5 wire     right seat heater switch, brown 6 pin plug, pin 5
Speed Sense     green/black     ac     driver kick, white 18 pin plug, pin 4
Brake Wire     brown/white     +     BIU right of steering column, white 34 pin plug (A), pin 10
Parking Brake     gray     -     BIU right of steering column, white 35 pin plug (C), pin 32
In order to make the ready mode neutral safety feature work properly with the electric parking brake on this vehicle, you need to use the + keysense (black/white) wire and the - parking brake (gray) wire, diode isolated and tied to the black/white neutral safety wire of the remote start. It works because the parking brake goes to sleep after a minute, and when the key is removed, the keysense stays negative. Also, the electric parking brake requires the foot brake to be pushed, so there is no way to accidentally disengage the parking brake with pushing the foot brake, thus disabling ready mode.
Horn Trigger     red     -     BIU right of steering column, white 34 pin plug (A), pin 24
Wipers     red/blue (LO); black/blue (HI); green/white (ignition)     +     wiper switch, white 18 pin plug, pins 8, 18, 9
Left Front Window (Up/Down)     blue/red - blue/green     A     power window main switch, white 16 pin plug, pins 16 - 13
Right Front Window (Up/Down)     red - red/blue     A     driver kick, white 28 pin plug, pins 5 - 6
Left Rear Window (Up/Down)     white/red - black/white     A     driver kick, white 28 pin plug, pins 9 - 10
Right Rear Window (Up/Down)     blue - blue/red     A     driver kick, white 28 pin plug, pins 7 - 8
Sun Roof (Open/Close)     black/yellow - white (function with ignition on only)     +     sunroof switch, white 5 pin plug, pins 1 - 4
Radio 12V     green/white and blue/red     +     radio, white 20 pin plug, pins 20, 19
Radio Ground     black     -     radio, white 20 pin plug, pin 10
Radio Ignition     yellow/red     +     radio, white 20 pin plug, pin 3
Radio Illumination     purple (parking lights); black/white (dimmer)     +,-     radio, white 20 pin plug, pins 1, 2
Factory Amp Turn-on     pink     +     radio, white 24 pin plug, pin 23
Power Antenna     yellow/black     +     radio, white 20 pin plug, pin 9
Left Front Speaker (+/-)     brown/white - green or black - green     +,-     radio, white 20 pin plug, pins 8 - 7
On models with amplifier, the speaker wires are brown - green at the amplifier under passenger seat, white 10 pin plug, pins 10 - 4. The tweeter wires are green/yellow - purple at the amplifier, white 12 pin plug, pins 9 - 3.
Right Front Speaker (+/-)     red/yellow - white/black or red - white     +,-     radio, white 20 pin plug, pins 18 - 17
On models with amplifier, the speaker wires are black/red - white/red at the amplifier under passenger seat, white 10 pin plug, pins 3 - 9. The tweeter wires are yellow - lt. green at the amplifier, white 12 pin plug, pins 2 - 1.
Left Rear Speaker (+/-)     white/red - red/black or white/blue - orange/blue     +,-     radio, white 20 pin plug, pins 6 - 5
On models with amplifier, the speaker wires are black/blue - white/blue at the amplifier under passenger seat, white 10 pin plug, pins 2 - 6.
Right Rear Speaker (+/-)     blue/yellow - red/white or blue/yellow - blue/grn     +,-     radio, white 20 pin plug, pins 16 - 15
On models with amplifier, the speaker wires are black - yellow at the amplifier under passenger seat, white 10 pin plug, pins 8 - 7.
Subwoofer (+/-)     blue - pink (1); blue/white - green (2)     +,-     amplifier under passenger seat, white 12 pin plug, pins 5-12; 4-10
Aux. Audio Input Left (+/-)     white - (shield)     +,-     radio, white 24 pin plug, pins 7 - 19, or 10 - 21
Aux. Audio Input Right (+/-)     red - (shield)     +,-     radio, white 24 pin plug, pins 8 - 19, or 22 - 21
Item     Size     Depth     Location
Headunit     irregular          center of dash
Left Front Speaker     6.5     3     left front door
Left Front Tweeter     1     1     left front dash
Right Front Speaker     6.5     3     right front door
Right Front Tweeter     1     1     right front dash
Left Rear Speaker     6.5     3     left rear door
Right Rear Speaker     6.5     3     right rear door
Subwoofer     8     3     rear deck (Legacy); R rear quarter panel (Outback)
Satellite Radio Tuner
Gary Sather
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
