2017 Hyundai Santa Fe Remote Start, Stereo Wiring
jimjaj97
Posted: January 04, 2018 at 2:51 PM / IP Logged Link to Post Post Reply Quote jimjaj97
Looking for an install diagram for a 2017 hyundai santa fe with key for a remote start. Any help would be appreciated.
monty_77
Copper - Posts: 491
Posted: February 16, 2018 at 11:34 PM / IP Logged Link to Post Post Reply Quote monty_77
Item             Wire Color     Polarity     Wire Location
12 Volts     red (40A)     +     ignition switch, black 6 pin plug, pin 1
Second 12 Volts     white (40A)     +     ignition switch, black 6 pin plug, pin 5
Ground             (chassis ground)
Starter             black             +     ignition switch, black 6 pin plug, pin 3
Ignition     green             +     ignition switch, black 6 pin plug, pin 4
Accessory     blue             +     ignition switch, black 6 pin plug, pin 2
Second Acc      pink             +     ignition switch, black 6 pin plug, pin 6
Keysense     green/orange     -     key switch, white 6 pin plug, pin 5
CAN Bus High     green (C-CAN)     data     data link connector, black 16 pin plug, pin 6
CAN Bus Low     orange (C-CAN)     data     data link connector, black 16 pin plug, pin 14
CAN Bus High 2     blue (B-CAN)     data     driver kick, white or blue 68 pin plug, pin 29
CAN Bus Low 2     red (B-CAN)     data     driver kick, white or blue 68 pin plug, pin 39
IMMO Data     blue (EMS COM)     data     driver kick, white or red 58 pin plug, pin 36
K Line             white     data     data    link connector, black 16 pin plug, pin 12
Power Lock     brown/orange     -     dash fuse box, rear, white 32 pin plug (E), pin 5
Power Unlock     yellow/black    -       (passenger doors)dash fuse box, rear, white 32 pin plug (E), pin 6
Power Unlock - Driver Door     -       (use driver unlock motor) or white relay box behind glove box, white 24 pin plug, pin 21
Lock Motor     orange             5 wire     dash fuse box, gray or black 51 pin plug (C), pin 48
Driver Unlock Motor     blue     5 wire     driver kick, white or blue 68 pin plug, pin 21
Passenger Unlock Motor     green     5 wire     dash fuse box, gray or black 51 pin plug (C), pin 47
Factory Alarm Arm     brown/black (key lock); red/orange (detection)      - and open     power window main switch, white 32 pin plug, pins 22, 24
Factory Alarm Disarm     pink/black (key unlock); red/orange (detection) both -     power window main switch, white 32 pin plug, pins 23, 24
Disarm No Unlock     (use keysense)
Parking Lights (+)     green/black (L); yellow/black (R)     +     dash fuse box, white 24 pin plug (D), pins 14, 16
Parking Lights (-)     pink     -     headlight switch, white 16 pin plug, pin 15
Hazards     pink     -     dash fuse box, rear, white 24 pin plug (H), pin 13
Turn Signal (Left)     yellow (F); gray (R)     +     dash fuse box, blue 31 pin plug (A), pin 6; white 24 pin plug (D), pin 21
Turn Signal (Right)     white (F); white/black (R)     +     dash fuse box, blue 31 pin plug (A), pin 2; white 24 pin plug (D), pin 1
Headlight     blue/orange     -     headlight switch, white 16 pin plug, pin 16
AutoLights     yellow     cut     headlight switch, white 16 pin plug, pin 14
Reverse Light     red     +     dash fuse box, gray or black 51 pin plug (C), pin 41
Left Front Door Trigger     gray/orange     -     power window main switch, white 32 pin plug, pin 21
Right Front Door Trigger     yellow/black     -     passenger power window switch, white 20 pin plug, pin 20
Left Rear Door Trigger     white     -     dash fuse box, white 24 pin plug (D), pin 9
Right Rear Door Trigger     brown/black     -     dash fuse box, white 24 pin plug (D), pin 8
Dome Light     brown     -     left front pillar, white 36 pin plug, pin 23
Trunk/Hatch Pin     white     -     dash fuse box, white 24 pin plug (D), pin 24
Hood Pin     pink/black     -     dash fuse box, blue 31 pin plug (A), pin 4
Power Liftgate     green/black     -     driver kick, white or blue 68 pin plug, pin 11
Trunk/Hatch Release     gray/black (rear handle switch)     -     dash fuse box, white 24 pin plug (D), pin 3
Trunk Release Motor     blue     +     dash fuse box, gray or black 51 pin plug (C), pin 19
Fuel Door Release     blue     +     driver kick, harness to rear
Tachometer     brown/orange (2.0L or 2.4L); green or gray (3.3L)     ac     camshaft position sensor on engine driver side, gray 3 pin plug, pin 3; black 3 pin plug, pin 2
Fuel Pump     pink     +     driver kick, white 25 pin plug, pin 2
Rear Defroster     green/orange     - latched     dash fuse box, blue 31 pin plug (A), pin 14
Mirror Defroster     (B-CAN)
Wiper Deicer     blue/orange or blue     - latched     dash fuse box, blue 31 pin plug (A), pin 12
Left Front Heated Seat     gray/black or brown/black     +     left seat warmer switch, white 26 pin plug, pin 2
Right Front Heated Seat     brown/black or gray/black     +     right seat warmer switch, green 26 pin plug, pin 2
Speed Sense     brown/orange     4-Pulse     radio, white 38 pin plug, pin 38 or white 24 pin plug, pin 16
Brake Wire     red/orange     +     driver kick, white or red 58 pin plug, pin 5
Parking Brake     gray/orange     -     dash fuse box, white 24 pin plug (D), pin 2
Horn Trigger     gray     -     driver kick, white or red 58 pin plug, pin 57
Wipers     orange/black     +     driver kick, white or red 58 pin plug, pin 52 or 29
Left Front Window (Up/Down)     white - pink (without auto up AND down only)     A     power window main switch, white 18 pin plug, pins 11 - 12
Right Front Window (Up/Down)     white - pink (without auto up AND down only)     A     passenger power window switch, white 18 pin plug, pins 11 - 12
Left Rear Window (Up/Down)     pink - brown     A     left rear power window switch, white 14 pin plug, pins 9 - 12
Right Rear Window (Up/Down)     blue - orange     A     right rear power window switch, white 14 pin plug, pins 9 - 12
Sun Roof (Open/Close)     gray/black - brown/black (function with ignition on only)     -     sunroof switch, white or black 6 pin plug, pins 2 - 3
Memory Seat 1     blue     -     power window main switch, white 32 pin plug, pin 19
Memory Seat 2     red/black     -     power window main switch, white 32 pin plug, pin 18
Audio
Radio 12V     pink or red     +     radio, white 24 pin plug, pin 12 or white 35 pin plug, pin 10
Radio Ground     black     -     radio, white 24 pin plug, pin 24 or white 35 pin plug, pin 12
Radio Ignition     brown     +     radio, white 24 pin plug, pin 11 or 18 or white 35 pin plug, pin 22
Radio Illumination     red/orange (parking lights); blue/orange (dimmer)     +,-     radio, white 18 pin plug, pins 8, 17 or white 35 pin plug, pins 6, 19
Factory Amp Turn-on     (M-CAN)
Power Antenna     green     +     radio, white 18 pin plug, pin 18 or white 35 pin plug, pin 5
Left Front Speaker (+/-)     brown - white     +,-     radio, white 18 pin plug, pins 2 - 11 or white 38 pin plug, pins 13 - 14
Right Front Speaker (+/-)     red - blue     +,-     radio, white 18 pin plug, pins 3 - 12 or white 38 pin plug, pins 16 - 15
Left Rear Speaker (+/-)     yellow - black     +,-     radio, white 18 pin plug, pins 1 - 10 or white 38 pin plug, pins 1 - 2
Right Rear Speaker (+/-)     green - orange     +,-     radio, white 18 pin plug, pins 4 - 13 or white 38 pin plug, pins 28 - 27
Center Channel (+/-)     white - black     +,-     amplifier under passenger seat, white 28 pin plug, pins 28 - 27 or 14 - 27
Subwoofer (+/-)     green - orange (1); blue - red (2)     +,-     amplifier under passenger seat, black 28 pin plug, pins 16 - 17; 18 - 19 or 2 - 17; 1 - 16
Aux. Audio Input Left (+/-)     green - black/orange or yellow - black/orange     +,-     radio, white 24 pin plug, pins 21 - 9 or white 38 pin plug, pins 24 - 25
Aux. Audio Input Right (+/-)     white - black/orange or brown - black/orange     +,-     radio, white 24 pin plug, pins 8 - 9 or white 38 pin plug, pins 10 - 25
Rearview Camera Video     red - black     +,-     radio, white 16 pin plug, pins 4 - 3 or white 38 pin plug, pins 7 - 21 or white 24 pin plug, pins 23 - 22
Satellite Radio 12 Volts     (built into radio)
