Noise!
Reddleman
Posted: June 22, 2002 at 9:18 PM / IP Logged
Okay, Finally got the stereo in the Toyota truck and amp.  But now I'm getting a lot of line noise.  What's the deal?
Dave
bberman1
Gold - Posts: 2,314
Posted: June 22, 2002 at 9:25 PM / IP Logged
When you say noise can you be more specific!
Reddleman
Posted: June 23, 2002 at 10:08 AM / IP Logged
Yeah, it's a hum that goes up in pitch when I accellerate...
bberman1
Gold - Posts: 2,314
Posted: June 23, 2002 at 11:18 AM / IP Logged
This was posted by anoter member ansering your question
Thumper2003 wrote:
ok .........a good place to start is with the way you wired you RCA cables and whether or not you ran them next to or (parallel) to the power cable........the power cable sometimes carrys a frequency made by the alternator.........if you have your RCA cables next to your power wire sometimes they will pick the noise up and you will hear it in your speakers........it is as simple to fix as re-routing your RCA cable away from your power wire.......      Hope this takes care of it .................Lee
ivanp2
Member - Posts: 10
Posted: June 25, 2002 at 5:42 PM / IP Logged
the same thing happened to me but even after i moved the power cable it still made the whinning noise. how can i get rid of it?
If possible please email me your replies to:
ivanp2@cox.net
CTMobileMedia
Copper - Posts: 43
Posted: June 25, 2002 at 6:22 PM / IP Logged
    Reddleman : you did ground the radio and amp to the same point right?
    Ivanp2: if you have to cross any wires, do so at 90 degree angles to minimize noise. You can also try getting a better quality shielded RCA cable too - popping for the higher grade signal wires can often resolve simpler noise issues.
   Dave
   CT Mobile Media
