2016 Chevy Cruze Limited Sedan Stereo Wiring Diagram
sharkland
Posted: September 13, 2018 at 4:16 PM / IP Logged Link to Post Post Reply Quote sharkland
I am trying to add a dual 600w amp and one 12 inch sub to my car. I think i will need a inline converter, but i am not sure as the wiring for my car. I do not have speakers in the back window above the trunk. i just have the door front and back with the tweeters in the dash. I would like to be able to add 6x9s in the position above the trunk also. There is a battery in the trunk but like i said do not know the diagrams.
sharkland
Posted: September 13, 2018 at 4:19 PM / IP Logged Link to Post Post Reply Quote sharkland
This is what my car looks like. 2016 Chevy Cruze Limited Sedan Stereo Wiring Diagram -- posted image.
Platinum - Posts: 13,725
Posted: September 13, 2018 at 8:03 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Smart Key?
Posted: September 13, 2018 at 8:04 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Left Front Speaker (+/-)      Blue - Brown/Blue      +,-      Radio in dash or behind glove box, brown 20 pin plug, pins 18 - 17 or green 16 pin plug, pins 1 - 9
Right Front Speaker (+/-)      Yellow - Yellow/Black      +,-      Radio in dash or behind glove box, brown 20 pin plug, pins 16 - 15 or green 16 pin plug, pins 2 - 10
Left Rear Speaker (+/-)      Green - Green/Black      +,-      Radio in dash or behind glove box, brown 20 pin plug, pins 13 - 14 or green 16 pin plug, pins 3 - 11
Right Rear Speaker (+/-)      White - Blue/Black      +,-      Radio in dash or behind glove box, brown 20 pin plug, pins 11 - 12 or green 16 pin plug, pins 4 - 12
sharkland
Posted: September 14, 2018 at 8:28 AM / IP Logged Link to Post Post Reply Quote sharkland
No smart key. Where did you find this information?
Posted: September 14, 2018 at 7:47 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Directed Electronics Database only available to their Customers.
Posted: September 14, 2018 at 8:12 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Info is the same for the regular key.
Posted: September 14, 2018 at 9:31 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      Red/Brown (30A)      +      BCM above driver kick, blue 27 pin plug, pin 4
Second 12 Volts      Red/Violet (2A only)      +      Ignition Switch, white 6 pin plug, pin 2
Ground      (chassis ground)
Starter      Yellow (for starter kill only)      +      Starter Motor or Underhood Fuse Box, gray 60 pin plug (X3), pin 34
Second Starter      White/Orange (R Code) (see Tech Doc 1605)      + 9600 Ohms      Ignition Switch, white 6 pin plug, pin 4
Ignition      Yellow/Blue      +      Ignition Switch, white 6 pin plug, pin 1
Accessory      Blue/White      +      Ignition Switch, white 6 pin plug, pin 3
Second Accessory      (same as second starter)      + 6300 Ohms
Keysense      (same as second starter)
CAN Bus High      Blue      Data      OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low      White      Data      OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus SW      Green      Data      OBD-Data Link Connector, black 16 pin plug, pin 1
OBD 12 Volts      Red/Violet (7.5A)      +      OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground      Black      -      OBD-Data Link Connector, black 16 pin plug, pin 4
IMMO Data      Green/Violet      Data      Immobilizer Control Module on ignition switch, violet 3 pin plug, pin 2
Power Lock      Brown/Yellow      -      BCM above driver kick, gray 26 pin plug, pin 18
Power Unlock      Brown/White      -      BCM above driver kick, pink 27 pin plug, pin 6
Lock Motor      Brown/Yellow      Reverse      BCM above driver kick, pink 27 pin plug, pin 4
Driver Unlock Motor      Gray      Reverse      BCM above driver kick, pink 27 pin plug, pin 1
Passenger Unlock Motor      Gray      Reverse      BCM above driver kick, pink 27 pin plug, pin 2
Factory Alarm Arm      (arms on lock with door open)
Factory Alarm Disarm      (Passkey and ignition)
Parking Lights      Brown/Blue (L); Brown/Gray (R)      +      BCM above driver kick, black 26 pin plug, pin 6 (L); pin 5 (R)
Parking Lights -      Green/Gray      -      Headlight Switch, black 12 pin plug, pin 3
Hazards      Green/White      -      BCM above driver kick, blue 27 pin plug, pin 26
Turn Signal (Left)      Blue/White (LF); Gray/Yellow (LR)      +      BCM above driver kick, brown 26 pin plug, pin 2 (LF); black 26 pin plug, pin 7 (LR)
Turn Signal (Right)      Green/Violet (RF); White/Yellow (RR)      +      BCM above driver kick, black 26 pin plug, pin 3 (RF); brown 26 pin plug, pin 7 (RR)
Headlight      White/Orange      -      Headlight Switch, black 12 pin plug, pin 4
AutoLights      Green/Brown      - (Off)      Headlight Switch, black 12 pin plug, pin 5
Reverse Light      Green/White      +      BCM above driver kick, gray 26 pin plug, pin 3
Left Front Door Trigger      Gray      -      Driver Window Motor, black 7 pin plug, pin 6
Right Front Door Trigger      Gray      -      Passenger Window Switch, black 8 pin plug, pin 6
Left Rear Door Trigger      Gray      -      Left Rear Window Switch, black 8 pin plug, pin 2
Right Rear Door Trigger      Gray      -      Right Rear Window Switch, black 8 pin plug, pin 2
Dome Light      Gray      +      BCM above driver kick, gray 26 pin plug, pin 1
Trunk/Hatch Pin      Violet/White      -      BCM above driver kick, pink 27 pin plug, pin 5
Hood Pin      Brown/Green      -      BCM above driver kick, black 26 pin plug, pin 24
Trunk/Hatch Release      Violet/Blue      -      BCM above driver kick, pink 27 pin plug, pin 14
Trunk Release Motor      Gray/Brown      +      BCM above driver kick, black 26 pin plug, pin 10
Tachometer      Brown, Blue, Green, or Gray/White (or Gray/Blue)      ac      Fuel Injector Harness on engine driver rear, black 12 pin plug, pin 2, 4, 9, 1
Clutch Pedal      Yellow      - 180 Ohms      Clutch Switch, black 3 pin plug, pin B
Fuel Pump      Violet/Green      +      Driver Kick, harness to rear
Rear Defroster      Brown/Yellow      + Latched      Driver Kick, black 102 pin plug, pin 51
Mirror Defroster      (same as rear defroster)
Left Front Heated Seat      (LIN Bus)
Right Front Heated Seat      (LIN Bus)
Speed Sense      (wheel speed sensor)
Brake Wire      Violet/White      +      BCM above driver kick, black 26 pin plug, pin 11
Parking Brake      Blue/Violet or Blue/Orange      -      BCM above driver kick, white 26 pin plug, pin 10
Horn Trigger      Brown/White      -      BCM above driver kick, brown 26 pin plug, pin 19
Wipers      Gray      +      BCM above driver kick, black 26 pin plug, pin 16
Left Front Window (Up/Down)      Green/Gray - Yellow/Violet (without auto up AND down only)      A      Driver Window Switch, black 8 pin plug, pins 2 - 3
Right Front Window (Up/Down)      Green/Gray - Yellow/Blue      A      Passenger Window Switch, black 8 pin plug, pins 2 - 3
Left Rear Window (Up/Down)      Blue/Violet - Yellow/Blue      A      Left Rear Window Switch, black 8 pin plug, pins 6 - 7
Right Rear Window (Up/Down)      Blue/Gray - Green/Black      A      Right Rear Window Switch, black 8 pin plug, pins 6 - 7
Sun Roof (Open/Close)      White (open) (functions with ignition on only)      - 100 Ohms      Sunroof Switch, black 4 pin plug, pin 4
Sun Roof (Limit/Close)      (close) (same as sun roof open)      - 940 Ohms
Radio 12V      Red/White      +      Radio in dash or behind glove box, brown 20 pin plug, pin 20 or green 16 pin plug, pin 8
Radio Ground      Black      -      Radio in dash or behind glove box, brown 20 pin plug, pin 10 or green 16 pin plug, pin 16
Radio Ignition      (Low Speed GMLAN)
Factory Amp Turn-on      (MOST Serial Data)
Left Front Speaker - With Amp      Blue - Brown/Blue      +,-      Amplifier in trunk right side, gray 8 pin plug, pins 3 - 7
Right Front Speaker - With Amp      Yellow - Yellow/Black      +,-      Amplifier in trunk right side, gray 8 pin plug, pins 2 - 6
Left Rear Speaker - With Amp      Green - Green/Black      +,-      Amplifier in trunk right side, green 16 pin plug, pins 7 - 15
Right Rear Speaker - With Amp      White - Blue/Black      +,-      Amplifier in trunk right side, green 16 pin plug, pins 6 - 14
Center Channel - With Amp      Yellow/White - Blue/Yellow      +,-      Amplifier in trunk right side, green 16 pin plug, pins 5 - 13
Subwoofer - With Amp      Blue/Gray - Green/Black (L); Green/Violet - Gray/Black (R)      +,-      Amplifier in trunk right side, gray 8 pin plug, pins 1 - 5 (L); green 16 pin plug, pins 16 - 8 (R)
Aux. Audio Input Left (+/-)      Gray - Violet      +,-      Radio in dash or behind glove box, gray 20 pin plug, pins 19 - 18 or 9 - 8
Aux. Audio Input Right (+/-)      Green - Violet      +,-      Radio in dash or behind glove box, gray 20 pin plug, pins 20 - 18 or 10 - 8
Rearview Camera Video      Gray/Yellow - White/Blue      +,-      Radio, gray 20 pin plug, pins 15 - 14 or Human Machine Interface Module behind glove box, gray 12 pin plug, pins 5 - 6
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
