2015 Infiniti QX60 Basic Alarm and Remote Start Wiring Diagram
csx898
Posted: October 02, 2018 at 12:10 PM / IP Logged Link to Post Post Reply Quote csx898
Hi. I need a alarm and remote start-wiring diagram for 2015 Infiniti QX60 basic with push start button.
Thank You for your
tonanzith
Gold - Posts: 603
Posted: December 08, 2018 at 9:33 PM / IP Logged Link to Post Post Reply Quote tonanzith
2015 Infiniti QX60 (Smart Key) - North America
        Item Wire Color Polarity Wire Location
          12 Volts white (40A) + BCM behind instrument cluster, white 15 pin plug, pin 11
          Ground (chassis ground)
          Starter white (non-hybrid); lt. blue (hybrid) - BCM behind instrument cluster, black 40 pin plug, pin 22
          Ignition green + BCM behind instrument cluster, black 40 pin plug, pin 27
          Second Ignition pink - BCM behind instrument cluster, black 40 pin plug, pin 30
          Accessory white + BCM behind instrument cluster, black 40 pin plug, pin 26
          Second Accessory blue + BCM behind instrument cluster, black 24 pin plug, pin 9
          PTS 1 green - BCM behind instrument cluster, green 40 pin plug, pin 1
          CAN Bus High blue data BCM behind instrument cluster, black 40 pin plug, pin 20
        CAN Bus Low pink data BCM behind instrument cluster, black 40 pin plug, pin 19
        IMMO Data
(NATS antenna is on the push-button ignition switch)
          Security Light violet - BCM behind instrument cluster, green 40 pin plug, pin 18
          Power Lock (use factory alarm arm)
          Power Unlock (use factory alarm disarm)
          Lock Motor blue 5 wire BCM behind instrument cluster, white 15 pin plug, pin 7
        Driver Unlock Motor violet 5 wire BCM behind instrument cluster, white 15 pin plug, pin 9
        Passenger Unlock Motor
lt. green 5 wire BCM behind instrument cluster, white 15 pin plug, pin 2
        Factory Alarm Arm brown or white (driver door key lock) - power window main switch, white 16 pin plug, pin 15
        Factory Alarm Disarm lt. blue (driver door key unlock) double - power window main switch, white 16 pin plug, pin 16
          Disarm No Unlock (proximity key and push-button)
          Parking Lights red + dash fuse box, brown 16 pin plug, pin 1
        Hazards lt. green - BCM behind instrument cluster, green 40 pin plug, pin 36
        Turn Signal (Left) lt. blue (F); beige (R) +
BCM behind instrument cluster, black 24 pin plug, pin 13; gray 24 pin plug, pin 23
          Turn Signal (Right) lt. green (F); red (R) +
BCM behind instrument cluster, black 24 pin plug, pin 1; gray 24 pin plug, pin 12
          Headlight blue (L), red (R) (LO); green (L), white (R) + headlights or underhood fuse box, white 8 pin plug, pins 3, (HI) 2; 8, 7
          Reverse Light lt. green + BCM behind instrument cluster, gray 24 pin plug, pin 24
        Left Front Door Trigger beige - BCM behind instrument cluster, gray 24 pin plug, pin 16
        Right Front Door Trigger
green - BCM behind instrument cluster, gray 24 pin plug, pin 14
          Left Rear Door Trigger white - BCM behind instrument cluster, gray 24 pin plug, pin 2
          Right Rear Door Trigger red - BCM behind instrument cluster, gray 24 pin plug, pin 13
          Dome Light lt. green - BCM behind instrument cluster, white 15 pin plug, pin 8
        Trunk/Hatch Pin white - BCM behind instrument cluster, gray 24 pin plug, pin 17
        Hood Pin red -
hood switch or underhood fuse box, white 16 pin plug, pin 15
          Trunk/Hatch Release lt. green (power liftgate open/close) - power liftgate switch, black 8 pin plug, pin 6
          Fuel Door Release (locks/unlocks along with driver door)
          Tachometer yellow or violet ac any fuel injector, gray 2 pin plug, pin 2
        Fuel Pump red to white (non-hybrid) + top of driver kick, white 12 pin plug, pin 1
      Note - Fuel Pump: On hybrid models, it is white (+) at the top of the driver kick, white 12 pin plug, pins 1 and 9 (common).
      Rear Defroster
beige
- latched
BCM behind instrument cluster, black 40 pin plug, pin 21
             Mirror Defroster
(same as rear defroster)
            Left Front Heated Seat
blue (heated only); pink (climate controlled)
    + resistor
left front heated seat switch, white 10 pin plug, pin 7 or 1
     Right Front Heated Seat
lt. green (heated only); blue (climate controlled)
      + resistor
right front heated seat switch, brown 8 pin plug, pin 6 or 1
     Speed Sense
beige
      8-Pulse
   radio, white 32 pin plug, pin 32 or 27
     Brake Wire
green
   BCM behind instrument cluster, green 40 pin plug, pin 27
     Parking Brake
lt. green
   parking brake switch, black 1 pin plug, pin 1
Horn Trigger
   red
    horn switch, yellow 6 pin plug, pin 1
     Wipers
yellow (LO); blue (HI)
wiper motor or underhood fuse box, white 12 pin plug, pins 5, 12
     Left Front Window (Up/Down)
(use factory alarm arm/disarm)
             Right Front Window (Up/Down)
(see left front window)
            Left Rear Window (Up/Down)
             Right Rear Window (Up/Down)
             Sun Roof (Open/Close)
blue - brown (function with ignition on only)
moonroof switch, white 8 pin plug, pins 2 - 1
     Memory Seat 1
violet
   driver kick, door harness, white 16 pin plug, pin 4
     Memory Seat 2
lt. green
   driver kick, door harness, white 16 pin plug, pin 13
     Radio 12V
yellow
   radio, white 20 pin plug, pin 19
     Radio Ground
gray or black
   radio, white 20 pin plug, pin 20
     Radio Ignition
pink or green
   radio, white 20 pin plug, pin 7
Radio Illumination
   red (without navigation)
    radio, white 20 pin plug, pin 9
     Factory Amp Turn-on
lt. blue
radio, white 20 pin plug, pin 1 or white 12 pin plug, pin 10
Power Antenna
   black
    radio, gray 3 pin plug, pin 1
   Left Front Speaker (+/-)
lt. blue - violet or black - white
radio, white 20 pin plug, pins 2 - 3 or white 12 pin plug, pins 7-1
Note - Left Front Speaker (+/-): On models with amplifier, the door and pillar speaker wires are green - red at the amplifier in rear cargo floor, brown 23 pin plug, pins 14 - 15. The dash speaker wires are red - green at the amplifier, brown 23 pin plug, pins 2 - 3.
Right Front Speaker (+/- )
brown - yellow, black - white, or white - black
radio, white 20 pin plug, pins 11 - 12 or white 12 pin plug, pins 11 - 5
Note - Right Front Speaker (+/-): On models with amplifier, the door and pillar speaker wires are white - pink at the amplifier in rear cargo floor, brown 23 pin plug, pins 4 - 5. The dash speaker wires are green - white at the amplifier, brown 14 pin plug, pins 9 - 8.
Left Rear Speaker (+/-)
brown - yellow or black - white
radio, white 20 pin plug, pins 4 - 5 or white 12 pin plug, pins 8-2
Note - Left Rear Speaker (+/-): On models with amplifier, the door speaker wires are pink - red at the amplifier in rear cargo floor, brown 23 pin plug, pins 1 - 11. The pillar speaker wires are white - green at the amplifier, brown 14 pin plug, pins 6 - 7.
Right Rear Speaker (+/-)
blue - lt. blue or black - white
radio, white 20 pin plug, pins 13 - 14 or white 12 pin plug, pins 12 - 6
Note - Right Rear Speaker (+/-): On models with amplifier, the door speaker wires are green - white at the amplifier in rear cargo floor, brown 14 pin plug, pins 5 - 14. The pillar speaker wires are white - green at the amplifier, brown 14 pin plug, pins 6 - 7.
Center Channel (+/-)
pink - red
   amplifier in rear cargo floor, brown 23 pin plug, pins 12 - 13
     Subwoofer (+/-)
white - black (1); red - green (2)
amplifier in rear cargo floor, brown 14 pin plug, pins 4 - 13; 10 - 11
     Aux. Audio Input Left (+/-)
white - black
radio, white 32 pin plug, pins 21 - 22 or white 28 pin plug, pins 11 - 24
             Aux. Audio Input Right (+/-)
red - black
radio, white 32 pin plug, pins 20 - 22 or white 28 pin plug, pins 25 - 24
        RSE Video (+/-)
black - white
radio, white 40 pin plug, pins 7 - 8
     Note - RSE Video (+/-): The front display video is white - black at the radio, white 24 pin plug, pins 2 - 1 (without navigation) or black - white at the radio, white 32 pin plug, pins 9 - 10 (with navigation).
             RSE Audio Left (+/-)
white - red
radio, white 28 pin plug, pins 9 - 23
        RSE Audio Right (+/-)
black - green
radio, white 28 pin plug, pins 8 - 22
              Satellite Radio 12 Volts
lt. blue
satellite radio in left rear quarter panel, white 16 pin plug, pin 12
Satellite Radio Ground
gray or brown
satellite radio in left rear quarter panel, white 16 pin plug, pin 15
Satellite Radio Ignition
beige
satellite radio in left rear quarter panel, white 16 pin plug, pin 16
        Satellite Radio Antenna
(coaxial cable)
              Satellite Audio Left (+/-)
black - white
satellite radio in left rear quarter panel, white 16 pin plug, pins 2 - 1
        Satellite Audio Right (+/-)
green - red
satellite radio in left rear quarter panel, white 16 pin plug, pins 4 - 3
      What Fits?
Item
Size
   Depth
   Location
     Headunit
irregular
     center of dash
     Left Front Speaker
6x9
        left front door
     Left Front Tweeter
3; 1
        left front dash; left front pillar
     Right Front Speaker
6x9
        right front door
     Right Front Tweeter
3; 1
        right front dash; right front pillar
     Left Rear Speaker
6.5
        left rear door
     Left Rear Tweeter
3; 1
        left rear pillar; left rear door
     Right Rear Speaker
6.5
        right rear door
     Right Rear Tweeter
3; 1
        right rear pillar; right rear door
     Center Channel
3
        top center of dash
     Subwoofer
6.5
        rear cargo floor
Satellite Radio Tuner
(built into radio with navigation)
Gary Sather
