Compustar CS4900-S, 2013 Honda Civic Wiring/Instructions?
akhmedovpulat
Posted: February 05, 2019 at 6:21 PM / IP Logged Link to Post Post Reply Quote akhmedovpulat
Hello,
I am trying to install Compustar CS4900-S with Fortin Honda-SL3 Honda Data Bypass on Honda Civic 2013. This is a 4-door, automatic car. Can you provide a wiring schematic and/or installation instructions, please? Thanks in advance.
motosaki
Member - Posts: 24
Posted: February 06, 2019 at 1:20 PM / IP Logged Link to Post Post Reply Quote motosaki
12 Volts     white (50A)     +     ignition switch, white 5 pin plug, pin 1
Ground     (chassis ground)
Starter     yellow     +     ignition switch, white 5 pin plug, pin 5
Ignition     blue     +     ignition switch, white 5 pin plug, pin 2
Accessory     orange     +     ignition switch, white 5 pin plug, pin 4
Second Accessory     red     +     ignition switch, white 5 pin plug, pin 3
Ignition Interrupt     yellow     cut     Immobilizer Control Unit on key switch, gray 7 pin plug, pin 6
Keysense     brown     -     key switch, blue 7 pin plug, pin 7
CAN Bus High     white (F-CAN)     data     data link connector, gray 16 pin plug, pin 6
CAN Bus Low     red (F-CAN)     data     data link connector, gray 16 pin plug, pin 14
CAN Bus High 2     pink (B-CAN)     data     Immobilizer Control Unit on key switch, gray 7 pin plug, pin 4
CAN Bus Low 2     blue (B-CAN)     data     Immobilizer Control Unit on key switch, gray 7 pin plug, pin 5
IMMO Data     lt. green (S-NET)     data     Immobilizer Control Unit on key switch, gray 7 pin plug, pin 2
Power Lock     blue     -     driver kick, door harness, blue 23 pin plug, pin 11
Power Unlock     gray     -     driver kick, door harness, blue 23 pin plug, pin 18
Lock Motor     blue     5 wire     driver kick, door harness, blue 23 pin plug, pin 21
Driver Unlock Motor     yellow     5 wire     driver kick, door harness, blue 23 pin plug, pin 22
Factory Alarm Arm     pink (driver door key lock)     -     driver kick, door harness, blue 23 pin plug, pin 23
Factory Alarm Disarm     brown (driver door key unlock)     -     driver kick, door harness, blue 23 pin plug, pin 9
Disarm No Unlock     (see factory alarm disarm)
Parking Lights     red     +     dash fuse box, green 44 pin plug (B), pin 29
Parking Lights -     gray     -     headlight switch, 12 pin plug, pin 8
Hazards     green     +     hazard switch, 5 pin plug, pin 4
Turn Signal (Left)     blue (F); blue (R)     +     dash fuse box, white 38 pin plg (C), pin 14; green 44 pin plug (B), pin 3
Turn Signal (Right)     brown (F); brown (R)     +     dash fuse box, white 38 pin plg (C), pin 6; green 44 pin plug (B), pin 24
Headlight     pink     -     headlight switch, 12 pin plug, pin 7
AutoLights     orange (ground to turn off autolights)     -     headlight switch, 12 pin plug, pin 1
Reverse Light     brown     +     dash fuse box, green 44 pin plug (B), pin 5
Left Front Door Trigger     green     -     dash fuse box, green 44 pin plug (B), pin 39
Right Front Door Trigger     lt. green     -     dash fuse box, green 44 pin plug (B), pin 18
Left Rear Door Trigger     brown     -     dash fuse box, green 44 pin plug (B), pin 27
Right Rear Door Trigger     gray     -     dash fuse box, green 44 pin plug (B), pin 28
Dome Light     pink     -     below dash fuse box, 28 pin plug, pin 18
Trunk/Hatch Pin     blue     -     dash fuse box, green 44 pin plug (B), pin 6
Hood Pin     lt. blue     -     dash fuse box, white 38 pin plug (C), pin 16
Trunk/Hatch Release     (use trunk release motor)
Trunk Release Motor     green     5 wire     dash fuse box, green 44 pin plug (B), pin 9
Tachometer     brn, red, blu, yel(non Si); pur, red, blu, tan(Si)     ac     any fuel injector, 2 pin plug, pin 1
Clutch Pedal     orange     -     clutch switch, yellow 2 pin plug, pin 2
Fuel Pump     green     +     dash fuse box, green 44 pin plug (B), pin 8
Rear Defroster     lt. green or brown     - latched     right of dash fuse box, 13 pin plug, pin 5
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     lt. green (LO); blue (HI)     + latched     driver seat heater switch, 6 pin plug, pins 1, 4
Right Front Heated Seat     green (LO); yellow (HI)     + latched     passenger seat heater switch, 7 pin plug, pins 1, 4
Speed Sense     blue (some models only)     ac     below dash FB, 28 pin plug, pin 5 or radio, gray 24 pin plug, pin 22
Brake Wire     lt. green     +     brake switch or dash fuse box, green 44 pin plug (B), pin 10
Parking Brake     lt. green     -     parking brake switch, 1 pin plug, pin 1
Horn Trigger     orange to pink     -     horn switch or dash fuse box, white 38 pin plug (C), pin 35
Wipers     blue     -     dash fuse box, white 38 pin plug (C), pin 8
Thats all the data I can get for the remote start end of installation, I dont have access to Fortins database sorry.
15yrs. in the industry. everything from simple deck installs, to remote starters, and full custom audio systems. I've Installed it all.
akhmedovpulat
Posted: February 06, 2019 at 5:19 PM / IP Logged Link to Post Post Reply Quote akhmedovpulat
Thank you very much!
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
