2011 Kia Sorrento Remote Start Wiring
piasa
Posted: March 23, 2019 at 5:27 AM / IP Logged Link to Post Post Reply Quote piasa
Does anyone have any links or info on what wires I need to splice to install a remote starter. The car model is below.
Vehicle:
Kia
Sorento
2011. Platinum. EX
Key-less Entree Factory Installed.
3rd party unit to be installed.
Remote Starter.
Avital Model 4105L (Could be a viper model 4105v) Sites such as installation guides already downloaded pdf.
avital com/Support/OwnersGuide.aspx Avital - Guides and Manuals
S P A M com 2011-kia-sorento-remote-start-system-wire-diagram/]2011 Kia Sorento Remote Start System Wire Diagram
and readyremote com
I would appreciate it so much if someone has done this before on this car.
I will not cut the yellow wire, and will not use a globe meter reader.
Thankyou
wirewise
Moderator - Posts: 489
Posted: March 23, 2019 at 6:59 AM / IP Logged Link to Post Post Reply Quote wirewise
SORENTO      2011-2013
KEY      T-HARNESS      IMMOBILIZER
N/A      N/A      KIA'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      RED (+), NOTE #2      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 1
STARTER      GREEN (+), NOTE #3      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 3
STARTER 2      BLACK/ORANGE(+) and PINK(+), (PUSH to START Button)      @ STAR/STOP BUTTON SWITCH, (BLACK, 10-PIN PLUG), PINS 1 and 7
IGNITION 1      ORANGE (+), NOTE #4      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 4
IGNITION 2      N/A
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      BLUE (+), NOTE #5      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 2
ACCESSORY/HEATER BLOWER 2      YELLOW (+), NOTE #6      @ IGNITION SWITCH, (BLACK, 6-PIN PLUG), PIN 6
KEYSENSE      N/A
PARKING LIGHTS ( - )      BLUE (-)      @ HEADLIGHT SWITCH, (WHITE, 13-PIN PLUG), PIN 2
PARKING LIGHTS ( + )      GREEN(+)(Left) and YELLOW(+)(Right), use both!      @ DASH FUSE BOX, (WHITE, 39-PIN PLUG(A), PINS 11 and 7
POWER LOCK      BLUE/BLACK (TYPE B)      @ DASH FUSE BOX, (WHITE, 26-PIN PLUG(FK), PIN 4
POWER UNLOCK      GRAY/BLACK (TYPE B), NOTE #7      @ DASH FUSE BOX, (WHITE, 26-PIN PLUG(FK), PIN 24
LOCK MOTOR WIRE      ORANGE (5-Wire Type)      @ DASH FUSE BOX, (WHITE, 39-PIN PLUG(A), PIN 16
DOOR TRIGGER      GREEN/ORANGE (-)      @ DASH FUSE BOX, (WHITE, 26-PIN PLUG(FK), PIN 10
DOMELIGHT SUPERVISION      BROWN (-)      @ LEFT FRONT A Pillar, (WHITE, 22-PIN PLUG), PIN 1
TRUNK RELEASE      YELLOW/BLACK (-), NOTE #9      @ DASH FUSE BOX, (WHITE, 26-PIN PLUG(FK), PIN 11
SLIDING POWER DOOR      N/A
HORN      GRAY/BLACK to GRAY (-)      in DRIVERS KICK PANEL, (WHITE, 15-PIN PLUG), PIN 6
TACH      Any wire NOT ORANGE or PINK/BLACK, (AC)      @ Any FUEL-INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      NOTE #10      @ BRAKE PEDAL SWITCH, (WHITE, 4-PIN PLUG), PIN 1
FACTORY ALARM DISARM      PINK(-) and GRAY(-), use both, NOTE #8      @ DASH FUSE BOX, (WHITE, 26-PIN PLUG(FK), PINS 9 and 26
ANTI-THEFT      KIA'S TRANSPONDER ANTI-THEFT SYSTEM, See NOTE #1      @ IGNITION SWITCH TUMBLER
NOTES
NOTE #1: This vehicle May Be Equipped with KIA'S TRANSPONDER ANTI-THEFT SYSTEM, check the OWNERS MANUAL for this vehicle or contact your HYUNDAI Dealer to see if the vehicle has a Special programmed Ignition Key, if it does, then for REMOTE STARTING you will need the 791 BYPASS Module and an Extra Ignition key.
NOTE #2: on Vehicles with SMART KEY, this wire is located in the DRIVERS KICK PANEL, (WHITE, 15-PIN PLUG), PIN 12
NOTE #3: on Vehicles with SMART KEY, this wire is a RED (+), located at the DASH FUSE BOX, (WHITE, 8-PIN PLUG(C), PIN 4
NOTE #4: on Vehicles with SMART KEY, this wire is a GREEN (+), located at the DASH FUSE BOX, (WHITE, 8-PIN PLUG(C), PIN 3
NOTE #5: on Vehicles with SMART KEY, this wire is located at the DASH FUSE BOX, (WHITE, 8-PIN PLUG(C), PIN 2
NOTE #6: on Vehicles with SMART KEY, this wire is located at the DASH FUSE BOX, (WHITE, 8-PIN PLUG), PIN 1
NOTE #7: to UNLOCK just the DRIVERS DOOR, use the YELLOW/BLACK (-), at the DASH FUSE BOX, (REAR WHITE, (16-PIN PLUG(MM), PIN 2
NOTE #8: to DISARM, use the PINK (-), TYPE B, and the GRAY (-) use both wires, will Require a Double Pulse. TEST these wires while turning the KEY in the Drivers Door.
NOTE #9: TEST this wire while Opening the TAILGATE with the Handle on the REAR of the Vehicle.
NOTE #10: the BRAKE wire is a YELLOW(+)(2.4L Engine) and a GREEN/BLACK(+)(3.5L Engine)
~wirewise~
wirewise
Posted: March 23, 2019 at 7:27 AM / IP Logged Link to Post Post Reply Quote wirewise
https://www.the12volt.com/installbay/forum_posts.asp?tid=120145
~wirewise~
piasa
Posted: March 24, 2019 at 5:25 AM / IP Logged Link to Post Post Reply Quote piasa
Thank you so much guys. I have seen this thread a couple of days before I joined this website.
I will find out if I realy need a 791 BYPASS Module. This car has a centre column to put in your key remote if the battery is flat. So possibly this could be the bypass module. I will find out.
The details on this site you have given is great but, would there be a little more detail in the notes? some images of past successful installs? Cos I can see the colors don't match with a few of the white 26 pin plug connections.
I will show some images of the fuse box when I get a chance to upload them.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
