03 toyota 4- runner wiring
sound decision
Member - Posts: 39
Posted: June 06, 2003 at 4:21 PM / IP Logged
looking to put in an alarm into a 4-runner any help will be great
thanks in advance
jayts95
Copper - Posts: 150
Posted: June 06, 2003 at 7:18 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white - WHITE/ red   |+ |ignition harness            |
|          STARTER|GREEN/ black or black|+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
| SECOND IGNITION|blk/red             |+ |ignition harness            |
|        ACCESSORY|blue/red            |+ |ignition harness            |
|       POWER LOCK|BROWN / white        |- |plug below fuse box *1      |
|     POWER UNLOCK|grn/yel & blu/yel *2|- |plug below fuse box *1      |
|       LOCK MOTOR|blue/white          |   |driver kick blue 12 pin plug|
|     UNLOCK MOTOR|pink/green          |   |driver kick blue 12 pin plug|
|    DISARM DEFEAT|BLACK / YELLOW        |   |driver kick harness to rear |
| PARKING LIGHTS +|green               |   |dimmer or harness to rear   |
| PARKING LIGHTS -|RED / white           |   |light switch or column      |
|       HEADLIGHTS|RED / yellow          |- |light switch or column      |
|     DOOR TRIGGER|lt. GREEN/ black     |- |*3                          |
| DOME SUPERVISION|use door trigger    |- |                            |
| TRUNK/HATCH PIN|lt. GREEN/ red       |- |driver kick 22 pin plug     |
|        HOOD PIN|GREEN/ orange        |- |*4                          |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|yellow/red *6       |- |steering column             |
|       TACHOMETER|black               |   |*5                          |
|       BRAKE WIRE|GREEN / WHITE        |+ |at switch                   |
|     HORN TRIGGER|GREEN/ red           |- |steering column             |
|           WIPERS|blue/blk - yel/blue |+ |at switch                   |
| LF WINDOW UP/DN|lt. green - blu/yel |A |inside drivers door        |
| RF WINDOW UP/DN|lt. green - blu/yel |A |inside passenger door       |
| LR WINDOW UP/DN|RED / blue - RED / yel |A |drivers kick panel          |
| RR WINDOW UP/DN|yellow - green     |A |drivers kick panel          |
| SUN RF OPN/CLOSE|blue/white - white |A |at switch or motor          |
|        RADIO 12V|blue / YELLOW        |+ |at radio                    |
|     RADIO GROUND|brown               |- |at radio                    |
|     RADIO SWITCH|gray               |+ |at radio                    |
| RADIO ILLUMINATE|violet              |+ |at radio                    |
|    POWER ANTENNA|BLACK/ white        |+ |at radio                    |
|       LF SPEAKER|pink - violet       |   |at radio or speaker        |
|       RF SPEAKER|lt.green - blue     |   |at radio or speaker        |
|       LR SPEAKER|black - yellow      |   |at radio or speaker        |
|       RR SPEAKER|red - white        |   |at radio or speaker        |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555F or 555U to bypass. *1 The door lock wires will meter while turning the key in the passenger door key cylinder. *2 The GREEN/ YELLOW wire is the key cylinder unlock wire, the blue / YELLOW wire is the unlock detection wire. Use both wires and diode isolate. *2 you must send ground to both wires and diode isolate. *3 behind drivers side junction block in a 13 pin plug. *4 drivers side firewall in a gray 26 pin plug. *5 located in the diagnostic plug on the drivers side of engine compartment. *6 This is the ignition key sense wire. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.
