2011 Kia Rondo Dash Illumination
unityco
Member - Posts: 6
Posted: September 01, 2019 at 4:09 PM / IP Logged Link to Post Post Reply Quote unityco
Hi all!
Over a year ago we replaced our dead OEM stereo with a cheap aftermarket. Since then, we’ve not had dash illumination when the headlights are on (everything’s fine when the headlights are off.) I finally had the chance today to take it all apart again and verify everything with a multi-meter. I was able to discern the illumination wire and the dimmer wire; they were both live and responded as expected. The new car stereo has no place to connect these (only constant, switched, ground and antenna power,) so they’re just capped in the dash. It seems the car doesn’t like this and wants them to go somewhere. No fuses are blown. Any ideas? Thanks!
Platinum - Posts: 13,723
Posted: September 01, 2019 at 5:15 PM / IP Logged Link to Post Post Reply Quote i am an idiot
They do not need to be connected for your dash lights to work. Is there not a dimmer knob somewhere on the dash to control the brightness of the dash lamps?
unityco
Member - Posts: 6
Posted: September 01, 2019 at 5:51 PM / IP Logged Link to Post Post Reply Quote unityco
There is, and the voltage on the wire changes when I turn it, but the dash stays dark.
Posted: September 01, 2019 at 8:36 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Have you removed the cluster to see if they are incandescent lamps or LED? If incandescent check the bulbs. Or either way check voltage across them.
unityco
Member - Posts: 6
Posted: September 01, 2019 at 8:47 PM / IP Logged Link to Post Post Reply Quote unityco
I have not, and really hope to avoid that step! Seems we may have to, or live without.
Thursday, November 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
