2019 Ford F-150, Alarm Wiring Info
mmcdan0342
Member - Posts: 11
Posted: September 17, 2019 at 2:47 PM / IP Logged Link to Post Post Reply Quote mmcdan0342
Hello! I can't seem to find the info on here, hoping for a hand (sorry if it is already posted and I missed it). I need alarm info for a 2019 F150 - mostly the horn trigger, but having the rest of the alarm-remote start info would be killer. Thanks!
Platinum - Posts: 13,725
Posted: September 18, 2019 at 1:08 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Smart Key or Conventional key?
mmcdan0342
Member - Posts: 11
Posted: September 20, 2019 at 8:01 AM / IP Logged Link to Post Post Reply Quote mmcdan0342
Conventional Key. I ended up just using a relay on the (+) horn wire under the hood (since I had the grille and shutters out anyway), but I would still like the info for future reference, as we have 3 more of these F150's coming down the line this month.
Posted: September 20, 2019 at 9:55 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      green/red (50A)      +      BCM in passenger kick, 22 pin plug (G), pin 22
Second 12 Volts      Green/Red (7.5A)      +      Gateway Module on data link connector, black 24 pin plug, pin 24
Ground      (chassis ground)
Ground 2      Black/Violet      -      Gateway Module on data link connector, black 24 pin plug, pin 14
Starter      blue/white      +      ignition switch, black 7 pin plug, pin 7      Directwire
Ignition      white/orange      +      ignition switch, black 7 pin plug, pin 1      Directwire
Accessory      violet/green      +      ignition switch, black 7 pin plug, pin 6      Directwire
Keysense      blue/gray      +      ignition switch, black 7 pin plug, pin 5      Directwire
CAN Bus High      white/blue (HS CAN)      data      Gateway Module on data link connector, black 24 pin plug, pin 20      Directwire
CAN Bus Low      white (HS CAN)      data      Gateway Module on data link connector, black 24 pin plug, pin 19      Directwire
CAN Bus High 2      gray/orange (MS CAN)      data      Gateway Module on data link connector, black 24 pin plug, pin 23      Directwire
CAN Bus Low 2      violet/orange (MS CAN)      data      Gateway Module on data link connector, black 24 pin plug, pin 22      Directwire
CAN Bus High 3      green/orange (HS2 CAN)      data      Gateway Module on data link connector, black 24 pin plug, pin 18
CAN Bus Low 3      gray/blue (HS2 CAN)      data      Gateway Module on data link connector, black 24 pin plug, pin 17
IMMO Data      blue/white (LIN bus)      data      PATS Transceiver on ignition switch, black 4 pin plug, pin 3      Directwire
Power Lock      gray/yellow      -      door lock switch in driver door, black 4 pin plug, pin 1 or black 8 pin plug, pin 7
Power Unlock      violet/gray      -      door lock switch in driver door, black 4 pin plug, pin 3 or black 8 pin plug, pin 8
Lock Motor      gray/brown      reverse      driver kick or BCM in passenger kick, 36 pin plug (C), pin 35
Driver Unlock Motor      blue/green      reverse      driver kick or BCM in passenger kick, 36 pin plug (C), pin 27
Passenger Unlock Motor      brown/green      reverse      BCM in passenger kick, 36 pin plug (C), pin 32
Factory Alarm Arm      (arms on lock)
Factory Alarm Disarm      (transponder and ignition)
Parking Lights      blue/gray (F); blue/gray (R)      +      BCM in passenger kick, 22 pin plug (G), pin 3; 36 pin plug (C), pin 12      Directwire
Parking Lights -      gray      -      headlight switch, black 16 pin plug, pin 11           Notes
Parking Lights Interrupt      black/violet      cut      headlight switch, black 16 pin plug, pin 4           Notes
Hazards      brown      -      hazard switch or BCM in passenger kick, black 52 pin plug (B), pin 19
Turn Signal (Left)      blue/green (F); gray/orange (R)      +      BCM in passenger kick, 40 pin plug (F), pin 39; 52 pin plug (E), pin 26
Turn Signal (Right)      yellow/violet (F); green/orange (R)      +      BCM in passenger kick, 40 pin plug (F), pin 38; 52 pin plug (E), pin 52
Headlight      blue      -      headlight switch, black 16 pin plug, pin 12
AutoLights      violet      cut      headlight switch, black 16 pin plug, pin 13
Reverse Light      green/brown      +      driver kick or BCM in passenger kick, 36 pin plug (C), pin 11
Left Front Door Trigger      brown      - N.C.      driver kick, harness to rear or BCM in passenger kick, 52 pin plug (E), pin 33      Directwire
Right Front Door Trigger      white      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 21
Left Rear Door Trigger      green      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 46
Right Rear Door Trigger      yellow      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 19
Dome Light      gray/violet      +      BCM in passenger kick, 36 pin plug (C), pin 13
Trunk/Hatch Pin      brown/yellow or yellow/orange (tailgate ajar)      -      driver kick or BCM in passenger kick, 52 pin plug (E), pin 34
Hood Pin      blue/orange      - N.C.      BCM in passenger kick, 40 pin plug (F), pin 14
Trunk/Hatch Release      brown/yellow (tailgate release) (rear handle switch)      -      driver kick or BCM in passenger kick, 52 pin plug (E), pin 14
Trunk Release Motor      green/white (tailgate release motor)      reverse      driver kick or BCM in passenger kick, 36 pin plug (C), pin 33
Tachometer      green/blue (fuel injector 1)      ac      PCM on passenger firewall, 95 pin plug, pin 84 or 86 (EcoBoost) or 1 (Ti-VCT)
Fuel Pump      yellow      -      BCM in passenger kick, 40 pin plug (F), pin 26
Rear Defroster      brown      - latched      climate control switch, 26 pin plug, pin 7
Mirror Defroster      (same as rear defroster)
Left Front Heated Seat      (MS CAN)
Right Front Heated Seat      (MS CAN)
Speed Sense      yellow/orange (except 10-speed transmission)      ac      PCM on passenger firewall, 95 pin plug, pin 12 (EcoBoost) or 26 (Ti-VCT)
Brake Wire      violet/white      +      brake switch or BCM in passenger kick, 22 pin plug (A), pin 1
Parking Brake      white/violet (without electric parking brake only)      -      parking brake switch or BCM in passenger kick, 52 pin plug (E), pin 47
Horn Trigger      green/white or lt. green/white      -      horn switch or BCM in passenger kick, black 52 pin plug (B), pin 18
Wipers      (LIN bus)
Left Front Window (Up/Down)      green - blue      A      Driver Door Module in door, 24 pin plug, pins 13 - 14
Right Front Window (Up/Down)      gray/yellow - green/white      A      Passenger Door Module in door, 24 pin plug, pins 13 - 14
Left Rear Window (Up/Down)      green/violet - brown      A      left rear window switch in door, 8 pin plug, pins 6 - 7
Right Rear Window (Up/Down)      white/violet - gray      A      right rear window switch in door, 8 pin plug, pins 6 - 7
Rear Sliding Window Open-Close      yellow - violet      +      window switch in roof, 6 pin plug, pins 3 - 2 or passenger kick, harness to rear
Sun Roof (Open/Close)      violet/brown - yellow/orange (function with ignition on only)      -      overhead console, 24 pin plug, pins 18 - 20
Memory Seat 1      violet/white      -      memory set switch in driver door, black 8 pin plug, pin 5
Memory Seat 2      yellow      -      memory set switch in driver door, black 8 pin plug, pin 4
Memory Seat 3      blue/orange      -      memory set switch in driver door, black 8 pin plug, pin 3
mmcdan0342
Member - Posts: 11
Posted: September 21, 2019 at 10:16 AM / IP Logged Link to Post Post Reply Quote mmcdan0342
Thanks! You're a rockstar! 2019 Ford F-150, Alarm Wiring Info -- posted image.
mr stylyn
Posted: November 28, 2019 at 7:15 PM / IP Logged Link to Post Post Reply Quote mr stylyn
Do you have the wiring info for the Smart key option as we have one with push to start and any wiring info would be amazing thank you.
Posted: November 28, 2019 at 8:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      Green/Red (50A)      +      BCM in passenger kick, 22 pin plug (G), pin 22
Second 12 Volts      Green/Red (7.5A)      +      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 24
Ground 2      Black/Violet      -      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 14
Starter Kill      Brown/Green      +      Next to Underhood Fuse Box, black 20 pin plug, pin 10
Ignition Sense      White      +      BCM in passenger kick, 22 pin plug (A), pin 16
PTS 1      Blue      +      Start Stop Button, black 6 pin plug, pin 1
PTS 2      Yellow      -      Start Stop Button, black 6 pin plug, pin 6
CAN Bus High      White/Blue (HS1 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 20      Directwire
CAN Bus Low      White (HS1 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 19      Directwire
CAN Bus High 2      Gray/Orange (MS CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 23      Directwire
CAN Bus Low 2      Violet/Orange (MS CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 22      Directwire
CAN Bus High 3      Green/Orange (HS2 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 18
CAN Bus Low 3      Gray/Blue (HS2 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 17
OBD 12 Volts      White/Red (10A)      +      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 13
OBD Ground      Black/Gray      -      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 1
OBD Connector      Black           Under Driver Dash, Below Steering Column
IMMO Antenna      (PATS antenna is in front of shifter or under armrest)
Power Lock      Gray/Yellow      -      Driver Door Lock Switch, black 4 pin plug, pin 1 or black 8 pin plug, pin 7
Power Unlock      Violet/Gray      -      Driver Door Lock Switch, black 4 pin plug, pin 3 or black 8 pin plug, pin 8
Lock Motor      Gray/Brown      Reverse      Driver Kick --or-- BCM in passenger kick, 36 pin plug (C), pin 35
Driver Unlock Motor      Blue/Green      Reverse      Driver Kick --or-- BCM in passenger kick, 36 pin plug (C), pin 27
Passenger Unlock Motor      Brown/Green      Reverse      BCM in passenger kick, 36 pin plug (C), pin 32
Factory Alarm Disarm      (proximity key and push button)
Parking Lights      Blue/Gray (F); Blue/Gray (R)      +      BCM in passenger kick, 22 pin plug (G), pin 3 (F); 36 pin plug (C), pin 12 (R)      Directwire
Parking Lights -      Gray      -      Headlight Switch, black 16 pin plug, pin 11           Notes
Parking Lights Interrupt      Black/Violet      Cut      Headlight Switch, black 16 pin plug, pin 4           Notes
Hazards      Brown      -      Hazard Switch --or-- BCM in passenger kick, black 52 pin plug (B), pin 19
Turn Signal (Left)      Blue/Green (LF); Gray/Orange (LR)      +      BCM in passenger kick, 40 pin plug (F), pin 39 (LF); 52 pin plug (E), pin 26 (LR)
Turn Signal (Right)      Yellow/Violet (RF); Green/Orange (RR)      +      BCM in passenger kick, 40 pin plug (F), pin 38 (RF); 52 pin plug (E), pin 52 (RR)
Headlight      Blue      -      Headlight Switch, black 16 pin plug, pin 12
AutoLights      Violet      Cut      Headlight Switch, black 16 pin plug, pin 13
Reverse Light      Green/Brown      +      Driver Kick --or-- BCM in passenger kick, 36 pin plug (C), pin 11
Left Front Door Trigger      Brown      - N.C.      Driver Kick, harness to rear --or-- BCM in passenger kick, 52 pin plug (E), pin 33      Directwire
Right Front Door Trigger      White      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 21
Left Rear Door Trigger      Green      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 46
Right Rear Door Trigger      Yellow      - N.C.      BCM in passenger kick, 52 pin plug (E), pin 19
Dome Light      Gray/Violet      +      BCM in passenger kick, 36 pin plug (C), pin 13
Trunk/Hatch Pin      Brown/Yellow or Yellow/Orange (tailgate ajar)      -      Driver Kick --or-- BCM in passenger kick, 52 pin plug (E), pin 34
Hood Pin      Blue/Orange      - N.C.      BCM in passenger kick, 40 pin plug (F), pin 14
Trunk/Hatch Release      Brown/Yellow (tailgate release) (rear handle switch)      -      Driver Kick --or-- BCM in passenger kick, 52 pin plug (E), pin 14
Trunk Release Motor      Green/White (tailgate release motor)      Reverse      Driver Kick --or-- BCM in passenger kick, 36 pin plug (C), pin 33
Tachometer      Brown/Blue (2.7L, 3.3L, 3.5L); White/Green (5.0L) (camshaft position sensor)      AC      PCM on passenger firewall, 126 pin plug, pin 76 (2.7L, 3.3L, 5.0L); 95 pin plug, pin 40 (3.5L)
Tachometer 2      Brown/Blue (3.0L diesel)      AC      PCM on passenger firewall, black 98 pin plug, pin 32
Fuel Pump      Blue      +      Underhood Fuse Box, bottom, black 50 pin plug, pin 50
Rear Defroster      Brown      - Latched      Climate Control Switch, 26 pin plug, pin 7
Speed Sense      Brown/Green (2.7L, 5.0L); Yellow/Orange (3.3L)      AC      PCM on passenger firewall, 90 pin plug, pin 51
Speed Sense 2      Brown/Green (3.5L, 3.0L diesel)      AC      TCM on passenger frame rail, black 50 pin plug, pin 42
Brake Wire      Violet/White      +      Brake Switch --or-- BCM in passenger kick, 22 pin plug (A), pin 1
Parking Brake      White/Violet (w/o EPB)      -      Parking Brake Switch --or-- BCM in passenger kick, 52 pin plug (E), pin 47
Horn Trigger      Green/White or Lt. Green/White      -      Horn Switch --or-- BCM in passenger kick, black 52 pin plug (B), pin 18
Wipers      (LIN)
Left Front Window (Up/Down)      Green - Blue      A      Driver Door Module, 24 pin plug, pins 13 - 14
Right Front Window (Up/Down)      Gray/Yellow - Green/White      A      Passenger Door Module, 24 pin plug, pins 13 - 14
Left Rear Window (Up/Down)      Green/Violet - Brown      A      Left Rear Window Switch, 8 pin plug, pins 6 - 7
Right Rear Window (Up/Down)      White/Violet - Gray      A      Right Rear Window Switch, 8 pin plug, pins 6 - 7
Rear Sliding Window Open-Close      Yellow - Violet      +      Sliding Window Switch, 6 pin plug, pins 3 - 2 --or-- Passenger Kick, harness to rear
Sun Roof (Open/Close)      Violet/Brown - Yellow/Orange (function with ignition on only)      -      Overhead Console, 24 pin plug, pins 18 - 20
Memory Seat 1      Violet/White      -      Memory Set Switch, black 8 pin plug, pin 5
Memory Seat 2      Yellow      -      Memory Set Switch, black 8 pin plug, pin 4
Memory Seat 3      Blue/Orange      -      Memory Set Switch, black 8 pin plug, pin 3
yitz0550
Member - Posts: 7
Posted: September 21, 2020 at 6:51 PM / IP Logged Link to Post Post Reply Quote yitz0550
Is this accurate for 2020 F250? Thanks in advance!
Ween
Platinum - Posts: 1,368
Posted: September 21, 2020 at 10:04 PM / IP Logged Link to Post Post Reply Quote Ween
Most of the information appears to be correct/the same. I was looking for the same info as you. These items are different: headlights, autolights, lf door trigger, hood pin, tachometer, clutch pedal, fuel pump, speed sense, horn trigger. There may be others.
yitz0550
Member - Posts: 7
Posted: September 21, 2020 at 10:28 PM / IP Logged Link to Post Post Reply Quote yitz0550
Hmmmm, would like to have some of those. Anybody with info for 2020 F250?
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
