Hornet 570t Remote Start, 2005 Toyota Camry
nh74
Posted: November 20, 2019 at 3:56 PM / IP Logged Link to Post Post Reply Quote nh74
Hello,
      i have a hornet 570t remote start that i want to install on my 05 Toyota Camry LE 4 cyl. i used to install these and viper units ages ago but i can not recall exactly how. i remember some of the units needed a relay for something but this remote starter did not come with one. any help is greatly appreciated.
Platinum - Posts: 7,828
Posted: November 21, 2019 at 8:50 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is a link to a wiring guide for your car :
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.aspx
Doing the install properly, you will need additional relays to support the second
Starter wire that this car has.
I uploaded a copy of the 570T install guide.   Here is a link :
https://www.the12volt.com/installbay/file.asp?ID=1447
The install looks pretty straight forward with the exception of the 2nd Starter wire.
For proper isolation you will need two 30/40 Amp SPDT relays with harnesses and a
couple inline fuse holders with appropriate fuses. Here is a diagram of those relays :
Hornet 570t Remote Start, 2005 Toyota Camry -- posted image.
nh74
Posted: November 22, 2019 at 10:27 AM / IP Logged Link to Post Post Reply Quote nh74
Thank you very meuch!
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
