Ignition Isolator Switch
damofinefidelit
Member - Posts: 7
Posted: December 28, 2019 at 4:05 AM / IP Logged Link to Post Post Reply Quote damofinefidelit
Hello,
      I have a 1994 Toyota Corolla in imaculate condition with only 90,000 kms on the clock and I'm upgrading the bottom end of the audio system, I'm currently running a $3,500 audio system and I'm upgrading the subwoofer power amp to an Alpine x series mono block power amp and I'll be installing a second 12" Alpine R Type dual 4 ohm sub in the same slot ported enclosure as am currently using.
   I am going to install GPS Trackers in the car and parts of the audio system but I was hoping I could install an ignition isolator switch inside the car and was hoping someone knows where to get GPS Trackers as well as suggestions to what switch to use either a key pad or hidden "momentary on" type switch.
geepherder
Platinum - Posts: 3,668
Posted: December 28, 2019 at 8:05 AM / IP Logged Link to Post Post Reply Quote geepherder
Browse the relay diagrams section on this site for starter kill. That should give you some ideas and you can modify the diagrams to your liking/for your application. Here's an example that uses the horn:
https://www.the12volt.com/relays/relaydiagram14.html
I've never used a GPS tracker before, so I can't help you there.
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
