2003 Lincoln Towncar Wiring, Remote Push Start Alarm
hustle8088
Posted: January 19, 2020 at 6:14 PM / IP Logged Link to Post Post Reply Quote hustle8088
I need the diagram for 2003 Lincoln towncar to install remote push start alarm? Will I need to install a bypass?
Tyrone Matthews
hustle8088
Posted: January 19, 2020 at 6:15 PM / IP Logged Link to Post Post Reply Quote hustle8088
It has chip in the key
Tyrone Matthews
wirewise
Moderator - Posts: 489
Posted: January 19, 2020 at 6:19 PM / IP Logged Link to Post Post Reply Quote wirewise
TOWN CAR      2003-2004
KEY      T-HARNESS      IMMOBILIZER
FDKEY-6      N/A      FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM, Requires 791 and Extra Ignition Key
PART      COLOR      LOCATION      DIAGRAM
12 VOLT CONSTANT      YELLOW (+) and LIGHT GREEN/PURPLE (+)      IGNITION SWITCH HARNESS
STARTER      RED/LIGHT BLUE (+)      IGNITION SWITCH HARNESS
STARTER 2      N/A
IGNITION 1      WHITE/YELLOW (+)      IGNITION SWITCH HARNESS
IGNITION 2      PINK/BLACK (+)      IGNITION SWITCH HARNESS
IGNITION 3      N/A
ACCESSORY/HEATER BLOWER 1      GRAY/YELLOW (+)      IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2      BLACK/LIGHT GREEN (+)      IGNITION SWITCH HARNESS
KEYSENSE      N/A
PARKING LIGHTS ( - )      WHITE/BLACK (-)      @ LCM Module, See NOTE *1
PARKING LIGHTS ( + )      BROWN (+)      @ LCM Module, See NOTE *1
POWER LOCK      PINK/YELLOW (TYPE A)      IN DRIVERS DOOR HARNESS
POWER UNLOCK      PINK/LIGHT GREEN (TYPE A)      IN DRIVERS DOOR HARNESS
LOCK MOTOR WIRE      PINK/BLACK (+)      IN DRIVERS DOOR HARNESS
DOOR TRIGGER      BLUE (-) and BLACK/ORANGE (-) Use both, See NOTE *5      @ DRIVERS DOOR Module, See NOTE *3 (-) NEGATIVE DOOR PIN ISOLATION
DOMELIGHT SUPERVISION      BLUE (-) Requires Relay      @ DRIVERS DOOR Module, See NOTE*3
TRUNK RELEASE      RED (5-Wire) See NOTE *2, Requires Relay
SLIDING POWER DOOR      N/A
HORN      DARK BLUE (-)      @ LCM Module, See NOTE *1
TACH      Any wire that is NOT RED or RED/LIGHT GREEN      @ ANY IGNITION COIL or FUEL INJECTOR
WAIT TO START LIGHT      N/A
BRAKE      LIGHT GREEN (+)      @ LCM Module, See NOTE *1
FACTORY ALARM DISARM      LIGHT BLUE/BLACK (-)      @ LCM Module, See NOTE *1
ANTI-THEFT      FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM      TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
NOTE *1 the LCM (Lighting Control Module) is located to the RIGHT of the STEERING COLUMN.
NOTE *2 this vehicle uses a 5-wire TRUNK RELEASE SYSTEM, that will require an extra Relay
NOTE *3 the DRIVERS DOOR Module is located below the mirror in the Drivers door.
NOTE *4 the TACH wire is located at the front of the motor, the coil is on the first spark plug on the drivers side.
NOTE *5 this vehicle has 2 Door trigger wires, when connecting to an ALARM SYSTEM, use both DOOR TRIGGER wires and DIODE ISOLATE
~wirewise~
