2019 Chevrolet Silverado, Alarm/Remote Start Wiring
caraudioholic24
Member - Posts: 37
Posted: February 04, 2020 at 7:37 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Hi there. I will be installing an Avital 4115L and an ADS-ALCA, 2019 Chevrolet Silverado standard key w/o onstar. Can I get the wiring. I like to have a back up plan in the event the bypass doesn't do its thing. Thank you in advance
caraudioholic24
Member - Posts: 37
Posted: February 05, 2020 at 4:47 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Any help would be appreciated
djdeito
Copper - Posts: 100
Posted: February 05, 2020 at 5:33 PM / IP Logged Link to Post Post Reply Quote djdeito
Could you provide more details about your 2019 Silverado. is it 8cyl, diesel, gas, 1500, 1500 LD, 2500, 3500?
icearrow6
Copper - Posts: 497
Posted: February 05, 2020 at 5:35 PM / IP Logged Link to Post Post Reply Quote icearrow6
2019 Chevrolet Silverado 1500 - North America
Item     Wire Color     Polarity     Wire Location
12 Volts     Red/Violet (30A)     +     BCM under driver dash, blue 27 pin plug, pin 4
Second 12 Volts     Red/Blue (2A)     +     Ignition Switch, black 6 pin plug, pin 4
Ground     (chassis ground)
Starter Kill     Yellow     +     Underhood Fuse Box, gray 44 pin plug (X3), pin B1
Second Starter     White/Violet (R Code) (see Tech Doc 1605)     + 9600 Ohms     Ignition Switch, black 6 pin plug, pin 2
Ignition     Violet/Black     +     Ignition Switch, black 6 pin plug, pin 5
Accessory     Violet/Yellow     +     Ignition Switch, black 6 pin plug, pin 3
Second Accessory     (same as second starter)     + 6300 Ohms
Keysense     (same as second starter)
CAN Bus High     Blue     Data     BCM under driver dash, white 26 pin plug, pin 25
CAN Bus Low     White     Data     BCM under driver dash, white 26 pin plug, pin 24
CAN Bus High 2     Blue/Black (DIAG CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low 2     White (DIAG CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus SW     Green     Data     BCM under driver dash, blue 27 pin plug, pin 22
CAN Bus SW 2     Green/White     Data     OBD-Data Link Connector, black 16 pin plug, pin 1
OBD 12 Volts     Red/White (10A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, black 16 pin plug, pin 4
IMMO Data     Green/Violet     Data     Immobilizer Control Module on ignition switch, black 3 pin plug, pin 2
IMMO Data 2     Green/Violet (alternate location)     Data     BCM under driver dash, green 25 pin plug, pin 2
Security Light     Gray     +     BCM under driver dash, white 26 pin plug, pin 21
Power Lock     Brown/Yellow     -     BCM under driver dash, gray 26 pin plug, pin 11
Power Unlock     Brown/White     -     BCM under driver dash, pink 27 pin plug, pin 27
Power Lock2     Yellow/Violet     -     BCM under driver dash, gray 26 pin plug, pin 21
Power Unlock2     Brown/Violet     -     BCM under driver dash, gray 26 pin plug, pin 24
Lock Motor     Brown/Yellow     Reverse     BCM under driver dash, pink 27 pin plug, pin 4
Driver Unlock Motor     Gray     Reverse     BCM under driver dash, pink 27 pin plug, pin 1
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (transponder and ignition)
Parking Lights     Violet/Gray (L); Gray/Brown (R)     +     Underhood Fuse Box, green or black 44 pin plug (X2), pin H3 (L); pin H5 (R)
Parking Lights -     Green/Gray     -     BCM under driver dash, white 26 pin plug, pin 22
Hazards     Green/White     -     BCM under driver dash, blue 27 pin plug, pin 26
Turn Signal (Left)     Blue/White (LF); Yellow/Blue (LR)     +     BCM under driver dash, brown 26 pin plug, pin 2 (LF); pin 1 (LR)
Turn Signal (Right)     Green/Violet (RF); Brown/Green (RR)     +     BCM under driver dash, black 26 pin plug, pin 3 (RF); pin 4 (RR)
Headlight     White/Violet     -     BCM under driver dash, white 26 pin plug, pin 16
AutoLights     Green/Brown     - (Off)     BCM under driver dash, white 26 pin plug, pin 11
Reverse Light     Green/White     +     Passenger Kick, black 76 pin plug, pin 40
Reverse Light 2     Green/White (alternate location)     +     Radio behind glove box, green 29 pin plug, pin 11 (base); gray 29 pin plug, pin 13 (premium)
Left Front Door Trigger     Gray or Pink (power window)     -     Driver Door Latch, green 10 pin plug, pin 1
Left Front Door Trigger 2     Gray (manual window)     -     BCM under driver dash, gray 26 pin plug, pin 25
Right Front Door Trigger     Gray (power window)     -     Passenger Door Latch, green 10 pin plug, pin 5
Right Front Door Trigger 2     Gray (manual window)     -     BCM under driver dash, gray 26 pin plug, pin 14
Left Rear Door Trigger     Gray or Green     -     Left Rear Window Switch, black 10 pin plug, pin 2
Right Rear Door Trigger     Green     -     Right Rear Window Switch, black 10 pin plug, pin 2
Dome Light     Gray     +     BCM under driver dash, white 26 pin plug, pin 23
Hood Pin     Brown/Green     -     BCM under driver dash, black 26 pin plug, pin 24
Power Liftgate     Gray (power tailgate)     - 1000 Ohms     Power Tailgate Switch, black 8 pin plug, pin 8
Power Liftgate 2     Gray (alternate location)     - 1000 Ohms     Passenger Kick, black 76 pin plug, pin 35
Trunk/Hatch Release     Brown (w/o power tailgate)     -     BCM under driver dash, pink 27 pin plug, pin 5
Trunk Release Motor     White/Green (w/o power tailgate)     +     BCM under driver dash, brown 26 pin plug, pin 11
Tachometer     Yellow/Violet (V8)     AC     Camshaft Position Sensor, engine front center on timing chain cover, black 3 pin plug, pin 3
Tachometer 2     Violet/Blue (base radio)     AC     Passenger Kick, black 76 pin plug, pin 46 --or-- Radio behind glove box, green 29 pin plug, pin 23
Fuel Pump     Violet/Green     +     Chassis to Body Junction Connector, engine compartment driver side, black 55 pin plug, pin 23
Rear Defroster     Brown/Violet     + Latched     Passenger Kick, black 76 pin plug, pin 58
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     (LIN)
Right Front Heated Seat     (LIN)
Heated Steering Wheel     (inside steering wheel)
Speed Sense     Green/Gray     AC     Passenger Kick, black 76 pin plug, pin 12
Brake Wire     Violet/White     +     BCM under driver dash, black 26 pin plug, pin 11
Brake Activation     Blue/Yellow     MUX     BCM under driver dash, blue 27 pin plug, pin 7
Parking Brake     (electric parking brake)
Horn Trigger     Green/White     -     BCM under driver dash, green 25 pin plug, pin 18
Horn Trigger 2     Brown/White (alternate location)     -     BCM under driver dash, brown 26 pin plug, pin 19
Wipers     Gray     +     BCM under driver dash, black 26 pin plug, pin 16
All Windows Up-Down     Gray/White (OPT1); Blue/Yellow (OPT2) (express down switch, if equipped)     -     BCM under driver dash, blue 27 pin plug, pin 15 (OPT1); black 26 pin plug, pin 19 (OPT2)
Memory Seat 1     White     - 630 Ohms     Driver Kick, door harness, black 52 pin plug, pin 12
Memory Seat 2     (same as memory seat 1)     - 2000 Ohms
caraudioholic24
Member - Posts: 37
Posted: February 05, 2020 at 6:02 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
1500 gas
Thank you very much.. i needed to fill in the blanks that idatalink didnt give me..
djdeito
Copper - Posts: 100
Posted: February 05, 2020 at 6:09 PM / IP Logged Link to Post Post Reply Quote djdeito
I am assuming you also have the Weblink cable which you will need for the key programming into the Alca bypass.
caraudioholic24
Member - Posts: 37
Posted: February 05, 2020 at 6:12 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Yes.. i have done quite a few, but needed to verify that I could tag 12 volts at the bcm.. etc.
Thank you for all the help..
Friday, August 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
