2018 Ford Fusion SE, Speaker Wire Diagram?
mproducerstudio
Member - Posts: 6
Posted: October 27, 2020 at 3:31 PM / IP Logged Link to Post Post Reply Quote mproducerstudio
I’m looking for the car stereo speaker wire diagram for a 2018 Ford Fusion SE I can’t seem to find it. Any help would be greatly appreciated thanks!
ThatOneUberDriver
Platinum - Posts: 13,725
Posted: October 27, 2020 at 6:25 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Radio 12V      White/Brown      +      Radio, black 24 pin plug, pin 1
Radio Ground      Black/Gray      -      Radio, black 24 pin plug, pin 13
Radio Ignition      Brown/Yellow (delayed accessory)      +      Driver Kick, door harness --or-- BCM-Dash Fuse Box, black 36 pin plug (F), pin 30
Radio Illumination      (HS CAN)
Factory Amp Turn-on      Violet/Red      +      Radio, black 26 pin plug, pin 18
Power Antenna      Green/Violet      +      Radio, black 24 pin plug, pin 2
Left Front Speaker (+/-)      White - White/Brown      +,-      Radio, black 24 pin plug, pins 22 - 10
Right Front Speaker (+/-)      White/Violet - White/Orange      +,-      Radio, black 24 pin plug, pins 23 - 11
Left Rear Speaker (+/-)      White/Green - Brown/Yellow      +,-      Radio, black 24 pin plug, pins 21 - 9
Right Rear Speaker (+/-)      Brown/White - Brown/Blue      +,-      Radio, black 24 pin plug, pins 24 - 12
Left Front Speaker - With Amp      White - White/Brown (woofer); Green/Orange - Gray/Orange (tweeter)      +,-      Amplifier in trunk right side, gray 16 pin plug, pins 2 - 10 (woofer); pins 3 - 11 (tweeter)
Right Front Speaker - With Amp      White/Violet - White/Orange (woofer); Violet/Orange - Yellow/Orange (tweeter)      +,-      Amplifier in trunk right side, gray 16 pin plug, pins 6 - 14 (woofer); pins 7 - 15 (tweeter)
Left Rear Speaker - With Amp      White/Green - Brown/Yellow      +,-      Amplifier in trunk right side, gray 16 pin plug, pins 4 - 12
Right Rear Speaker - With Amp      Brown/White - Brown/Blue      +,-      Amplifier in trunk right side, gray 16 pin plug, pins 8 - 16
Center Channel - With Amp      Green - Gray/Yellow (F); Green/Brown - Violet/Brown (R)      +,-      Amplifier in trunk right side, gray 16 pin plug, pins 1 - 9 (F); pins 5 - 13 (R)
Subwoofer - With Amp      Green/Violet - Gray (L); Violet - Yellow (R)      +,-      Amplifier in trunk right side, 16 pin plug, pins 2 - 10 (L); pins 1 - 9 (R)
