2019 Toyota Highlander Alarm Wiring
cpottie
Posted: August 25, 2021 at 3:26 PM / IP Logged Link to Post Post Reply Quote cpottie
Looking for alarm wiring for 2019 Highlander. Specifically looking for door lock/unlock wires, and door pins, trunk pin.
Standard Key vehicle, no factory alarm.
Platinum - Posts: 13,725
Posted: August 26, 2021 at 9:17 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      Black (30A) or Tan (7.5A)      +      Ignition Switch, white 8 pin plug, pin 4
Second 12 Volts      White (5A)      +      Ignition Switch, white 8 pin plug, pin 5
12 Volts 3      Green (40A)      +      Dash Fuse Box, white 1 pin plug (4L), pin 1      Directwire
Ground      (chassis ground)
Starter      Blue (w/o Stop Start System)      +      Ignition Switch, white 8 pin plug, pin 2
Second Starter      Gray      +      Ignition Switch, white 8 pin plug, pin 6
Ignition      Black      +      Ignition Switch, white 8 pin plug, pin 3
Second Ignition      Green      +      Ignition Switch, white 8 pin plug, pin 8
Accessory      Gray      +      Ignition Switch, white 8 pin plug, pin 7
Ignition Interrupt      Yellow (TPMS) (w/o Stop Start System)      Cut      Dash Fuse Box, white 36 pin plug (4H), pin 30      Directwire
Ignition Interrupt 2      Red (TPMS) (with Stop Start System)      Cut      Driver Kick, gray 22 pin plug, pin 9      Directwire
Keysense      Gray      -      Key Switch, white 2 pin plug, pin 1
CAN Bus High      Violet (DIAG CAN)      Data      OBD-Data Link Connector, white 16 pin plug, pin 6      Directwire
CAN Bus Low      White (DIAG CAN)      Data      OBD-Data Link Connector, white 16 pin plug, pin 14      Directwire
CAN Bus High 2      Red      Data      Body ECU on dash fuse box, white 30 pin plug, pin 14      Directwire
CAN Bus Low 2      White      Data      Body ECU on dash fuse box, white 30 pin plug, pin 13      Directwire
OBD 12 Volts      Violet (7.5A)      +      OBD-Data Link Connector, white 16 pin plug, pin 16      Directwire
OBD Ground      White/Black      -      OBD-Data Link Connector, white 16 pin plug, pin 4      Directwire
IMMO Data      White (IMO)      Data      Left of Dash Fuse Box, gray 18 pin plug, pin 14
IMMO Data 2      Black (IMI)      Data      Left of Dash Fuse Box, gray 18 pin plug, pin 15
SIL Data      Lt. Blue      Data      OBD-Data Link Connector, white 16 pin plug, pin 7      Directwire
Security Light      Gray      +      Dash Fuse Box, rear, white 56 pin plug (4A), pin 42
RDA      Lt. Green      Data      Body ECU on dash fuse box, white 30 pin plug, pin 4      Directwire
Power Lock      Red (passenger switch)      -      Dash Fuse Box, rear, white 32 pin plug (4D), pin 22
Power Unlock      White (passenger switch)      -      Dash Fuse Box, rear, white 32 pin plug (4D), pin 27
Lock Motor      Brown      Reverse      Driver Kick, gray 18 pin plug, pin 10
Driver Unlock Motor      Tan      Reverse      Driver Kick, gray 18 pin plug, pin 18
Passenger Unlock Motor      Lavender/Pink      Reverse      Dash Fuse Box, white 36 pin plug (4H), pin 10
Factory Alarm Arm      Violet (key lock)      -      Body ECU on dash fuse box, white 30 pin plug, pin 29      Directwire
Factory Alarm Disarm      Lt. Blue (key unlock)      Double -      Body ECU on dash fuse box, white 30 pin plug, pin 2      Directwire
Disarm No Unlock      (use keysense)
Parking Lights      Lt. Green      +      Dash Fuse Box, white 32 pin plug (4F), pin 4
Parking Lights -      Lt. Green      -      Headlight Switch, black 20 pin plug, pin 18
Hazards      Pink      -      A/C Control Assembly, black 8 pin plug, pin 7
Turn Signal (Left)      Green      +      Dash Fuse Box, white 36 pin plug (4H), pin 7
Turn Signal (Right)      Red      +      Dash Fuse Box, white 36 pin plug (4H), pin 6
Headlight      White      -      Headlight Switch, black 20 pin plug, pin 19
AutoLights      Black      Cut      Headlight Switch, black 20 pin plug, pin 20
Reverse Light      Red      +      Dash Fuse Box, white 36 pin plug (4H), pin 18
Left Front Door Trigger      Gray      -      Body ECU on dash fuse box, white 30 pin plug, pin 6      Directwire
Right Front Door Trigger      Blue      -      Body ECU on dash fuse box, white 30 pin plug, pin 27      Directwire
Left Rear Door Trigger      Lt. Blue      -      Dash Fuse Box, white 36 pin plug (4H), pin 36
Right Rear Door Trigger      Lt. Green      -      Dash Fuse Box, rear, white 32 pin plug (4D), pin 30
Dome Light      Lavender/White      -      Dash Fuse Box, rear, white 32 pin plug (4D), pin 12
Trunk/Hatch Pin      Lavender/Yellow      -      Dash Fuse Box, white 36 pin plug (4H), pin 33
Rear Glass Pin      Red      -      Body ECU on dash fuse box, white 28 pin plug, pin 27      Directwire
Hood Pin      Black      -      Body ECU on dash fuse box, white 30 pin plug, pin 11      Directwire
Power Liftgate      Gray      -      Power Liftgate Switch on dash --or-- Body ECU on dash fuse box, white 28 pin plug, pin 5      Directwire
Trunk/Hatch Release      Red (liftgate); Green (glass) (rear handle switch)      -      Body ECU on dash fuse box, white 30 pin plug, pin 18 (liftgate); white 28 pin plug, pin 28 (glass)      Directwire
Trunk Release Motor      Lavender/Lt. Blue (liftgate) (w/o power liftgate)      Reverse      Dash Fuse Box, white 36 pin plug (4H), pin 4
Fuel Door Release      Yellow      -      Fuel Lid Opener Switch on dash, black 5 pin plug, pin 4
Tachometer      Blue (w/o Stop Start System)      AC      OBD-Data Link Connector, white 16 pin plug, pin 9      Directwire
Tachometer 2      Blue, Black, or Red (with Stop Start System)      AC      Any Fuel Injector, black 2 pin plug, pin 2
Fuel Pump      Red (I-4); Blue (V6)      +      Driver Kick, white 18 pin plug, pin 13
Rear Defroster      Blue      -      Left of Dash Fuse Box, black 18 pin plug, pin 9
Mirror Defroster      (same as rear defroster, w/o memory); (CAN Bus, with memory)
Wiper Deicer      Lt. Blue      -      Left of Dash Fuse Box, black 18 pin plug, pin 15
Left Front Heated Seat      Lt. Blue      + Latched      Seat Heater Switch, white 10 pin plug, pin 3 or black 12 pin plug, pin 6
Right Front Heated Seat      Tan      + Latched      Seat Heater Switch, black 8 pin plug, pin 2 or black 12 pin plug, pin 11
Speed Sense      Gray or Tan      AC      Radio, white 28 pin plug, pin 17
Brake Wire      Green to Blue      +      Brake Switch --or-- Dash Fuse Box, white 36 pin plug (4H), pin 3
Parking Brake      Green      -      Dash Fuse Box, white 32 pin plug (4F), pin 28      Directwire
Horn Trigger      Green      -      Dash Fuse Box, white 32 pin plug (4F), pin 29      Directwire
Wipers      Black (LO); Red (HI)      +      Wiper Switch, white 10 pin plug, pin 3 (LO); pin 4 (HI)      Directwire
Wipers Protection      White (ignition)      Cut      Wiper Switch, white 10 pin plug, pin 2      Directwire
Left Front Window (Up/Down)      (use factory alarm arm/disarm)
Right Front Window (Up/Down)      (use factory alarm arm/disarm)
Left Rear Window (Up/Down)      Yellow - White (w/o jam protection)      A      Driver Kick, gray 18 pin plug, pins 2 - 12
Right Rear Window (Up/Down)      Lt. Blue - Lt. Green (w/o jam protection)      A      Driver Kick, gray 18 pin plug, pins 1 - 11
Sun Roof (Open/Close)      (use factory alarm arm/disarm)
Memory Seat 1      Yellow      -      Seat Memory Switch, white 8 pin plug, pin 4
Memory Seat 2      Green      -      Seat Memory Switch, white 8 pin plug, pin 3
Radio 12V      Lt. Blue or Lavender/Lt. Blue      +      Radio, white 10 pin plug, pin 4
Radio Ground      Brown      -      Radio, white 10 pin plug, pin 7
Radio Ignition      Gray      +      Radio, white 10 pin plug, pin 3
Radio Illumination      Green (parking lights); White (dimmer)      +,-      Radio, white 10 pin plug, pin 10 (parking lights); white 6 pin plug, pin 5 (dimmer)
Left Front Speaker (+/-)      Lavender/Black - Lavender/Gray or Brown - Lt. Blue      +,-      Radio, white 10 pin plug, pins 2 - 6
Right Front Speaker (+/-)      Lt. Green - Blue or White - Black or Lt. Green - Pink      +,-      Radio, white 10 pin plug, pins 1 - 5
Left Rear Speaker (+/-)      Blue - Red or Green - Red      +,-      Radio, white 6 pin plug, pins 2 - 6
Right Rear Speaker (+/-)      Pink - Gray      +,-      Radio, white 6 pin plug, pins 1 - 3
Left Front Speaker - With Amp      Pink - Violet      +,-      Amplifier under center console, white 30 pin plug, pins 11 - 26
Right Front Speaker - With Amp      Lt. Green - Blue      +,-      Amplifier under center console, white 30 pin plug, pins 15 - 30
Left Front Tweeter - With Amp      Black - Gray      +,-      Amplifier under center console, white 30 pin plug, pins 13 - 28
Right Front Tweeter - With Amp      White - Black or Lt. Green - Blue      +,-      Amplifier under center console, white 30 pin plug, pins 14 - 29
Left Rear Speaker - With Amp      Blue - Red      +,-      Amplifier under center console, white 30 pin plug, pins 4 - 19
Right Rear Speaker - With Amp      Pink - Gray      +,-      Amplifier under center console, white 30 pin plug, pins 12 - 27
Left Rear Surround - With Amp      Yellow - Tan      +,-      Amplifier under center console, white 30 pin plug, pins 5 - 20
Right Rear Surround - With Amp      Red - White      +,-      Amplifier under center console, white 30 pin plug, pins 9 - 24
Center Channel - With Amp      Lt. Blue - Brown      +,-      Amplifier under center console, white 30 pin plug, pins 10 - 25
Subwoofer - With Amp      Black - Lt. Blue (coil 1); Yellow - Gray (coil 2)      +,-      Amplifier under center console, white 30 pin plug, pins 8 - 23 (coil 1); pins 7 - 22 (coil 2)
Aux. Audio Input Left (+/-)      White - Black      +,-      Radio, white 28 pin plug, pins 28 - 27
Aux. Audio Input Right (+/-)      Red - Black      +,-      Radio, white 28 pin plug, pins 26 - 27
Rearview Camera Video      Red - White or Green - Red      +,-      Radio, white 24 pin plug, pins 12 - 24
RSE Audio Left (+/-)      Black - Green      +,-      Radio, white 12 pin plug, pins 4 - 5
RSE Audio Right (+/-)      Red - White      +,-      Radio, white 12 pin plug, pins 2 - 3
Satellite Radio 12 Volts      Red      +      Satellite Radio below radio, white 8 pin plug, pin 4
Satellite Radio Ground      Black      -      Satellite Radio below radio, white 8 pin plug, pin 8
Satellite Radio Ignition      Yellow      +      Satellite Radio below radio, white 8 pin plug, pin 3
Satellite Radio Antenna      (coaxial cable)
Satellite Audio Left (+/-)      (DIN cable)
Satellite Audio Right (+/-)      (DIN cable)
