Ignition Wiring, 2008 Pontiac Montana
arlinelizotte76
Posted: November 14, 2021 at 12:03 PM / IP Logged Link to Post Post Reply Quote arlinelizotte76
The van has power sometime when turning key,then won't the next time
2008pontiac montanna sometimes has power when turning the key and other times doesnt
Platinum - Posts: 13,725
Posted: November 14, 2021 at 3:49 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      Red/White      +      At BCM Left of Steering Column, C1 Pin 51      Directwire
Second 12 Volts      Red/White      +      At BCM Left of Steering Column, C1 Pin 52      Directwire
Ground      (chassis ground)
Starter      Yellow      +      At BCM Left of Steering Column, C1 Pin 21      Directwire
Ignition      Pink      +      At BCM Left of Steering Column, C1 Pin 22      Directwire
Accessory      Brown      +      At BCM Left of Steering Column, C1 Pin 23      Directwire
Keysense      Lt. Green      -      At BCM Left of Steering Column, C1 Pin 40
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
