2014 Volkswagen Beetle, Remote Start Wiring
caraudioholic24
Member - Posts: 37
Posted: December 21, 2021 at 12:37 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Good Afternoon, I need wiring info for 2014 Volkswagen Beetle. I am doing a remote start and possibly keyless entry (due to factory alarm). Direct tech would be awesome. Have a great day..
lectricguy
Copper - Posts: 359
Posted: December 21, 2021 at 6:56 PM / IP Logged Link to Post Post Reply Quote lectricguy
Here you go...This is for the standard key Beetle...
Item     Wire Color     Polarity     Wire Location
12 Volts     Red/Yellow (30A)     +     VESCM under driver dash, black 73 pin plug, pin 68
Second 12 Volts     Red/Violet (5A)     +     Ignition Switch, black 10 pin plug, pin 1
Ground     (chassis ground)
Starter     Red/Black     +     Ignition Switch, black 10 pin plug, pin 4
Ignition     Black/Violet     +     Ignition Switch, black 10 pin plug, pin 8
Accessory     Black/Red     +     Ignition Switch, black 10 pin plug, pin 3
Keysense     Black/Gray     +     Ignition Switch, black 10 pin plug, pin 2
CAN Bus High     Orange/Black     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     Orange/Brown     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus High 2     Orange/Green     Data     VESCM under driver dash, white 73 pin plug, pin 20
CAN Bus Low 2     Orange/Brown     Data     VESCM under driver dash, white 73 pin plug, pin 21
OBD 12 Volts     Red/White (10A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Brown     -     OBD-Data Link Connector, black 16 pin plug, pin 4
OBD Ignition     Black/Blue     +     OBD-Data Link Connector, black 16 pin plug, pin 1
IMMO Antenna     Blue     RF     Immobilizer Reader Coil on ignition switch, 2 pin plug, pin 1
Power Lock     Brown/Green     - 560 Ohms     VESCM under driver dash, black 73 pin plug, pin 25
Power Unlock     (same as power lock)     -
Lock Motor     Blue/Green     Reverse     VESCM under driver dash, black 73 pin plug, pin 11
Driver Unlock Motor     Blue/Violet     Reverse     VESCM under driver dash, black 73 pin plug, pin 12
Passenger Unlock Motor     Brown/Yellow     Reverse     VESCM under driver dash, black 73 pin plug, pin 15
Factory Alarm Arm     Blue/Red (key lock)     -     VESCM under driver dash, black 73 pin plug, pin 24
Factory Alarm Disarm     (same as factory alarm arm)     - 180 Ohms
Disarm No Unlock     (transponder and ignition)
Parking Lights     Gray/Red     +     VESCM under driver dash, black 73 pin plug, pin 45
Hazards     Brown/Red     -     VESCM under driver dash, black 73 pin plug, pin 28
Turn Signal (Left)     Black/White     +     VESCM under driver dash, white 73 pin plug, pin 14
Turn Signal (Right)     Black/Green     +     VESCM under driver dash, white 73 pin plug, pin 15
Headlight     White     +     VESCM under driver dash, white 73 pin plug, pin 52
Reverse Light     Blue/Black     +     VESCM under driver dash, white 73 pin plug, pin 12 or 48
Left Front Door Trigger     Brown/Yellow     -     VESCM under driver dash, black 73 pin plug, pin 19
Right Front Door Trigger     Brown/Yellow     -     VESCM under driver dash, black 73 pin plug, pin 20
Dome Light     Red/Blue     -     VESCM under driver dash, black 73 pin plug, pin 4
Trunk/Hatch Pin     Brown/Black     -     VESCM under driver dash, black 73 pin plug, pin 30
Hood Pin     Brown/Green     -     VESCM under driver dash, black 73 pin plug, pin 27
Trunk/Hatch Release     Violet (rear handle switch)     -     VESCM under driver dash, black 73 pin plug, pin 23
Trunk Release Motor     Red/Blue     Reverse     VESCM under driver dash, black 73 pin plug, pin 10
Fuel Door Release     (unlocks along with driver door)
Tachometer     Blue/Gray (gasoline)     AC     Camshaft Position Sensor, engine driver side front, 3 pin plug, pin 2
Tachometer 2     Green/Brown or Green/Violet (diesel)     AC     Camshaft Position Sensor, engine passenger front or center front, 3 pin plug, pin 2
Clutch Pedal     Violet/White (1.8L, diesel)     -     VESCM under driver dash, white 73 pin plug, pin 55
Clutch Pedal 2     Violet/White (2.0L)     -     ECM next to battery, 91 pin plug, pin 62
Fuel Pump     Black/Blue (gasoline); Blue/Red (diesel)     +     Driver Kick, harness to rear
Rear Defroster     Black     + Latched     VESCM under driver dash, white 73 pin plug, pin 63
Mirror Defroster     Blue/White     -     VESCM under driver dash, white 73 pin plug, pin 58
Left Front Heated Seat     (CAN and LIN)
Right Front Heated Seat     (CAN and LIN)
Speed Sense     (wheel speed sensor)
Brake Wire     Black/Red (functions with ignition on only)     +     VESCM under driver dash, black 73 pin plug, pin 43
Parking Brake     Brown/Yellow     -     Parking Brake Switch, 2 pin plug, pin 1
Horn Trigger     Black/White     +     VESCM under driver dash, black 73 pin plug, pin 72
Horn - Factory Alarm     Violet     +     VESCM under driver dash, black 73 pin plug, pin 53
Wipers     Violet/Blue (LO); Violet (HI)     +     Wiper Switch, 10 pin plug, pin 4 (LO); pin 6 (HI)
Wipers Protection     Black/Blue (ignition)     Cut     Wiper Switch, 10 pin plug, pin 3
All Windows Up-Down     (use factory alarm arm/disarm)
Sun Roof (Open/Close)     Brown/Green - Violet/Green (tilt up/down) (function with ignition on only)     -     Sunroof Switch, 6 pin plug, pins 4 - 6
Convertible Top Open-Close     Blue - Green (function with ignition on only)     -     Power Top Switch, 4 pin plug, pins 3 - 4
Radio 12V     Red/Yellow or Red/Gray     +     Radio, black 8 pin plug, pin 8 or 16 pin plug, pin 16
Radio Ground     Brown     -     Radio, black 8 pin plug, pin 7 or 16 pin plug, pin 12
Radio Ignition     (CAN)
Radio Illumination     (CAN)
Factory Amp Turn-on     (CAN)
Left Front Speaker (+/-)     Brown/Green - Brown/Blue or Green - Brown     +,-     Radio, brown 8 pin plug, pins 3 - 7 or 16 pin plug, pins 3 - 7
Right Front Speaker (+/-)     Brown/Red - Brown/Black or Blue - Brown     +,-     Radio, brown 8 pin plug, pins 2 - 6 or 16 pin plug, pins 2 - 6
Left Rear Speaker (+/-)     Red/White - Brown/White or White - Brown     +,-     Radio, brown 8 pin plug, pins 4 - 8 or 16 pin plug, pins 4 - 8
Right Rear Speaker (+/-)     Red/Violet - Brown/Violet or Yellow - Brown     +,-     Radio, brown 8 pin plug, pins 1 - 5 or 16 pin plug, pins 1 - 5
Left Front Speaker - With Amp     Brown/Red - Brown/Black (woofer); Red/Green - Brown/Green (midrange)     +,-     Amplifier under driver seat, 38 pin plug, pins 6 - 18 (woofer); pins 13 - 14 (midrange)
Right Front Speaker - With Amp     Brown/Green - Brown/Blue (woofer); Red/Gray - Brown/Gray (midrange)     +,-     Amplifier under driver seat, 38 pin plug, pins 3 - 15 (woofer); pins 12 - 11 (midrange)
Left Front Tweeter - With Amp     Gray/Yellow - Gray/Blue     +,-     Amplifier under driver seat, 38 pin plug, pins 8 - 20
Right Front Tweeter - With Amp     Green/Yellow - Green/Blue     +,-     Amplifier under driver seat, 38 pin plug, pins 19 - 7
Left Rear Speaker - With Amp     Red/White - Brown/White     +,-     Amplifier under driver seat, 38 pin plug, pins 9 - 21
Right Rear Speaker - With Amp     Red/Violet - Brown/Violet     +,-     Amplifier under driver seat, 38 pin plug, pins 22 - 10
Subwoofer - With Amp     Gray/Brown - Gray/Red (coil 1); Brown/Red - White/Red (coil 2)     +,-     Amplifier under driver seat, 38 pin plug, pins 4 - 16 (coil 1); pins 17 - 5 (coil 2)
Aux. Audio Input Left (+/-)     Gray - Yellow     +,-     Radio, green 12 pin plug, pins 7 - 1
Aux. Audio Input Right (+/-)     Green - Yellow     +,-     Radio, green 12 pin plug, pins 2 - 1
Lectric Guy
caraudioholic24
Member - Posts: 37
Posted: December 22, 2021 at 5:16 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Thank you very much
