2018 Honda CR-V, Remote Start Wiring
caraudioholic24
Member - Posts: 37
Posted: December 22, 2021 at 5:17 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Good Evening, I have a 2018 Honda CR-V.. Normal key and I need the wiring diagram for it. Im doing a remote start/keyless.. Thank you
lectricguy
Copper - Posts: 359
Posted: December 22, 2021 at 7:48 PM / IP Logged Link to Post Post Reply Quote lectricguy
Here you go...
Item     Wire Color     Polarity     Wire Location
12 Volts     White (50A)     +     Ignition Switch, 5 pin plug, pin 1
Ground     (chassis ground)
Starter     Yellow     +     Ignition Switch, 5 pin plug, pin 5
Ignition     Blue     +     Ignition Switch, 5 pin plug, pin 2
Accessory     White     +     Ignition Switch, 5 pin plug, pin 4
Second Accessory     Red     +     Ignition Switch, 5 pin plug, pin 3
Ignition Interrupt     Blue     Cut     Immobilizer Keyless Control Unit on ignition switch, 7 pin plug, pin 6
Keysense     Pink     -     Key Switch, 7 pin plug, pin 7
CAN Bus High     White (F-CAN)     Data     OBD Data Link Connector, white 16 pin plug, pin 6
CAN Bus Low     Red (F-CAN)     Data     OBD Data Link Connector, white 16 pin plug, pin 14
CAN Bus High 2     Pink (B-CAN)     Data     Immobilizer Keyless Control Unit on ignition switch, 7 pin plug, pin 4
CAN Bus Low 2     Blue (B-CAN)     Data     Immobilizer Keyless Control Unit on ignition switch, 7 pin plug, pin 5
OBD 12 Volts     White (10A)     +     OBD-Data Link Connector, white 16 pin plug, pin 16
OBD Ground     Violet     -     OBD-Data Link Connector, white 16 pin plug, pin 4
OBD Connector     White          Under Driver Dash, Right of Dash Fuse Box
IMMO Data     Lt. Green (S-NET)     Data     Immobilizer Keyless Control Unit on ignition switch, 7 pin plug, pin 2
K Line     Lt. Blue     Data     OBD Data Link Connector, white 16 pin plug, pin 7
Power Lock     (use factory alarm arm and lock detection)
Power Unlock     (use factory alarm disarm and unlock detection)
Power Lock2     Blue (if needed)     -     BCM behind dash fuse box, blue 36 pin plug, pin 27
Power Unlock2     Pink (passenger doors) (if needed)     -     BCM behind dash fuse box, blue 36 pin plug, pin 32
Power Unlock - Driver Door     Green (if needed)     -     BCM behind dash fuse box, blue 36 pin plug, pin 31
Lock Motor     Pink     Reverse     Driver Kick, door harness
Driver Unlock Motor     Blue     Reverse     Driver Kick, door harness
Passenger Unlock Motor     White     Reverse     Dash Fuse Box, 22 pin plug, pin 16
Factory Alarm Arm     Violet     -     Power Window Master Switch, 37 pin plug, pin 3
Factory Alarm Disarm     Red     Double -     Power Window Master Switch, 37 pin plug, pin 4
Lock Detection     Blue     -     Power Window Master Switch, 37 pin plug, pin 18
Unlock Detection     Lt. Blue     Double -     Power Window Master Switch, 37 pin plug, pin 17
Parking Lights     Violet (L); Red (R)     +     Driver Kick, harness to rear
Parking Lights -     Gray     -     Headlight Switch, 12 pin plug, pin 8
Hazards     Green     -     BCM behind dash fuse box, tan 28 pin plug, pin 2
Turn Signal (Left)     Blue (LF); Lt. Blue (LR)     +     BCM behind dash fuse box, blue 36 pin plug, pin 18 (LF); pin 17 (LR)
Turn Signal (Right)     Brown (RF); Lt. Green (RR)     +     BCM behind dash fuse box, blue 36 pin plug, pin 35 (RF); pin 34 (RR)
Headlight     Pink     -     Headlight Switch, 12 pin plug, pin 7
AutoLights     Pink     - (Off)     Headlight Switch, 12 pin plug, pin 1
Reverse Light     Lt. Green     +     Dash Fuse Box, 22 pin plug, pin 11
Left Front Door Trigger     Green     -     BCM behind dash fuse box, gray 40 pin plug, pin 22
Right Front Door Trigger     Lt. Green     -     BCM behind dash fuse box, gray 40 pin plug, pin 23
Left Rear Door Trigger     Brown     -     BCM behind dash fuse box, gray 40 pin plug, pin 24
Right Rear Door Trigger     Gray     -     BCM behind dash fuse box, gray 40 pin plug, pin 28
Dome Light     White     -     BCM behind dash fuse box, white 14 pin plug, pin 13
Trunk/Hatch Pin     White     -     BCM behind dash fuse box, gray 40 pin plug, pin 27
Hood Pin     Red to Blue     - N.C.     Hood Switch --or-- Relay Control Module on underhood fuse box, 6 pin plug, pin 5
Power Liftgate     Lt. Blue and Yellow     Connect With Relay     Driver Power Liftgate Switch, 4 pin plug, pins 3, 4 or 12 pin plug, pins 5, 4
Trunk/Hatch Release     Pink (rear handle switch)     -     BCM behind dash fuse box, tan 28 pin plug, pin 4
Trunk Release Motor     Green (w/o power liftgate)     Reverse     Dash Fuse box, 22 pin plug, pin 8
Tachometer     Lt. Violet/Green     AC     Camshaft Position Sensor, engine driver side front, 3 pin plug, pin 3
Fuel Pump     Green     +     Driver Kick, harness to rear
Rear Defroster     Red     + Latched     Driver Kick, harness to rear
Left Front Heated Seat     (B-CAN)
Right Front Heated Seat     (B-CAN)
Speed Sense     Blue (some models only)     AC     Radio, 24 pin plug, pin 21
Brake Wire     Pink to Green     +     Brake Switch --or-- BCM behind dash fuse box, tan 28 pin plug, pin 25
Parking Brake     Brown (EPB)     -     Electric Parking Brake Switch, 12 pin plug, pin 6
Horn Trigger     Red     -     Horn Switch, 20 pin plug, pin 10
Wipers     Violet (INT/LO); White (HI/LO)     -     Wiper Switch, 10 pin plug, pin 7 (INT/LO); pin 6 (HI/LO)
Wipers Protection     Brown (Ground)     Cut     Wiper Switch, 10 pin plug, pin 9
All Windows Up-Down     (use factory alarm arm/disarm)
Sun Roof (Open/Close)     (use factory alarm arm/disarm)
Memory Seat 1     Gray     -     Power Window Master Switch, 37 pin plug, pin 1
Memory Seat 2     Red     -     Power Window Master Switch, 37 pin plug, pin 2
Lectric Guy
caraudioholic24
Member - Posts: 37
Posted: December 23, 2021 at 6:56 AM / IP Logged Link to Post Post Reply Quote caraudioholic24
Hello Fellow Rhode islander.. Thank you again.
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
