2021 Chevrolet Eqinox, Non Bose, Stereo Wiring
sparxx513
Copper - Posts: 56
Posted: June 22, 2022 at 12:03 PM / IP Logged Link to Post Post Reply Quote sparxx513
Looking for the stereo wiring diagram. Wanting to add a Kicker Key to the door and dash speakers. Also if the dash speakers are in parallel with the door speakers.
Thanks in advance.
Platinum - Posts: 13,725
Posted: June 22, 2022 at 9:03 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Radio 12V      Red/Yellow      +      Radio behind glove box, green or black 29 pin plug, pin 1 or brown 20 pin plug, pin 20 or green 16 pin plug, pin 8
Radio Ground      Black      -      Radio behind glove box, green or black 29 pin plug, pin 3 or brown 20 pin plug, pin 10 or green 16 pin plug, pin 16
Radio Ignition      (Low Speed GMLAN)
Factory Amp Turn-on      Green/Yellow (or MOST Serial Data)      +      Radio behind glove box, gray 20 pin plug, pin 12 or 2 or gray 29 pin plug, pin 14
Left Front Speaker (+/-)      Blue - Brown/Blue      +,-      Radio behind glove box, gray 29 pin plug, pins 2 - 5 or brown 20 pin plug, pins 18 - 17 or green 16 pin plug, pins 1 - 9
Right Front Speaker (+/-)      Yellow - Yellow/Black      +,-      Radio behind glove box, gray 29 pin plug, pins 6 - 3 or brown 20 pin plug, pins 16 - 15 or green 16 pin plug, pins 2 - 10
Left Rear Speaker (+/-)      Green - Green/Black      +,-      Radio, gry 29 pin plg, pin 1; grn or blk 29 pin plg, pin 8 or brn 20 pin plg, pins 13 - 14 or grn 16 pin plg, pins 3 - 11
Right Rear Speaker (+/-)      White - Blue/Black      +,-      Radio behind glove box, gray 29 pin plug, pins 8 - 4 or brown 20 pin plug, pins 11 - 12 or green 16 pin plug, pins 4 - 12
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
