2010 GMC Sierra Work Truck, Stereo Wiring
redownton
Posted: December 04, 2022 at 9:44 AM / IP Logged Link to Post Post Reply Quote redownton
Trying to identify wiring on the stock stereo to install aftermarket. Closest I found on site was 2009 Sierra 1500. here is what Ive found
Light blue
yellow
dark blue
brown
yellow
green
light green
different shade light green
tan, possibly orange
black
red with white stripe
gray
I watched a members video on how to test. Do not have equipment. was hoping someone could identify before cutting the factory clips off
Richard E Downton
geepherder
Platinum - Posts: 3,668
Posted: December 05, 2022 at 5:33 AM / IP Logged Link to Post Post Reply Quote geepherder
You can buy an adapter harness like the Metra 70-2105 that will match the wiring of your new receiver. This way you won't need to cut any plugs. The downside is this your truck doesn't have an accessory wire in the harness from the factory. That's why there's a long red wire- so you can run your own.
Even if you decide to cut the factory plugs you still need to run an accessory wire to be able to power your deck with the turn of the key.
If don't mind spending more, the Access AXADBX-2 or a similar interface will provide you with an accessory output.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
