2024 Toyota Tacoma PTS, Remote Start Wiring
Home /
the12volt's Install Bay /
Vehicle Wiring Information & File Requests / 2024 Toyota Tacoma PTS, Remote Start Wiring
Welcome Guest :)
Posted: May 22, 2024 at 5:44 PM / IP Logged
Item Wire Color Polarity Wire Location Photo Note
12 Volts White (80A) + Passenger Dash Fuse Box, white 1 pin plug (A54), pin 1 Directwire
Second 12 Volts Lavender/White (20A) + Driver Kick, door harness, white 28 pin plug (J102), pin 6
12 Volts 3 Red (7.5A) + Certification ECU above driver kick, top white 30 pin plug, pin 6 Directwire
Ground (chassis ground)
Ground 2 Brown - Certification ECU above driver kick, top white 30 pin plug, pin 29 Directwire
Starter Blue + Certification ECU above driver kick, bottom white 30 pin plug, pin 10 Directwire
Ignition White + Certification ECU above driver kick, bottom white 30 pin plug, pin 24 Directwire
Second Ignition Lt. Green + Certification ECU above driver kick, bottom white 30 pin plug, pin 11 Directwire
Accessory Black + Certification ECU above driver kick, top white 30 pin plug, pin 21 Directwire
Telematics Interrupt Lt. Blue Cut Passenger Dash Fuse Box, rear gray 45 pin plug (J90), pin 8
Telematics Interrupt 2 Lt. Blue (alternate location) Cut Telematics Transceiver behind center of dash, gray 34 pin plug, pin 1
PTS 1 Gray - Certification ECU above driver kick, top white 30 pin plug, pin 19 Directwire
PTS 2 Violet - Certification ECU above driver kick, top white 30 pin plug, pin 27 Directwire
PTS 3 Tan - Certification ECU above driver kick, top white 30 pin plug, pin 23 Directwire
CAN Bus High Black Data Certification ECU above driver kick, top white 30 pin plug, pin 1 Directwire
CAN Bus Low White Data Certification ECU above driver kick, top white 30 pin plug, pin 2 Directwire
CAN Bus High 2 Gray Data Body ECU on passenger dash fuse box, bottom black 30 pin plug, pin 2 Directwire
CAN Bus Low 2 White Data Body ECU on passenger dash fuse box, bottom black 30 pin plug, pin 1 Directwire
CAN Bus High 3 Lt. Green (DIAG CAN) Data OBD-Data Link Connector, white 16 pin plug, pin 6 Directwire
CAN Bus Low 3 White (DIAG CAN) Data OBD-Data Link Connector, white 16 pin plug, pin 14 Directwire
OBD 12 Volts Gray (7.5A) + OBD-Data Link Connector, white 16 pin plug, pin 16 Directwire
OBD Ground White/Black - OBD-Data Link Connector, white 16 pin plug, pin 4 Directwire
OBD Connector White Under Driver Dash, Near Hood Release
IMMO Data Blue (IMO) Data Top of Driver Kick, white 63 pin plug (AJ1), pin 37 Directwire
IMMO Data 2 Tan (IMI) Data Top of Driver Kick, white 63 pin plug (AJ1), pin 13 Directwire
IMMO Antenna Green - Blue RF Engine Start Stop Switch, black 12 pin plug, pins 1 - 7
IMMO Antenna 2 Green - Blue RF Certification ECU above driver kick, top white 30 pin plug, pins 12 - 13 Directwire
Driver LF Antenna Green - Red RF Outside Antenna in driver outside handle, black or gray 6 pin plug, pins 4 - 6
Driver LF Antenna 2 Blue - White RF Certification ECU above driver kick, top white 30 pin plug, pins 16 - 15 Directwire
Passenger LF Antenna Green - Red RF Outside Antenna in passenger outside handle, black or gray 6 pin plug, pins 4 - 6
Passenger LF Antenna 2 Black - White RF Certification ECU above driver kick, top white 30 pin plug, pins 10 - 9 Directwire
Center LF Antenna Pink - Green RF Inside Antenna under middle of center console, black 2 pin plug, pins 1 - 2
Center LF Antenna 2 Pink - Green RF Certification ECU above driver kick, top white 30 pin plug, pins 4 - 5 Directwire
Rear LF Antenna Blue - White RF Outside Antenna in middle of rear bumper, black 2 pin plug, pins 2 - 1
Rear LF Antenna 2 Blue - White RF Certification ECU above driver kick, middle white 27 pin plug, pins 4 - 3 Directwire
Rear Handle Switch Pink - Certification ECU above driver kick, middle white 27 pin plug, pin 16 Directwire
Security Light Pink + Certification ECU above driver kick, top white 30 pin plug, pin 25 Directwire
RDA Lt. Green Data Certification ECU above driver kick, middle white 27 pin plug, pin 11 Directwire
Power Lock (use factory alarm arm)
Power Unlock (use factory alarm disarm)
Power Lock2 Blue (passenger switch) (if needed) - Body ECU on passenger dash fuse box, white 27 pin plug, pin 6 Directwire
Power Unlock2 Lt. Green (passenger switch) (if needed) - Body ECU on passenger dash fuse box, white 27 pin plug, pin 7 Directwire
Lock Motor Black Reverse Driver Kick, door harness, yellow 26 pin plug (J101), pin 1 --or-- Passenger Dash Fuse Box, rear gray 45 pin plug (J90), pin 19
Driver Unlock Motor Lavender/Blue Reverse Driver Kick, door harness, yellow 26 pin plug (J101), pin 2 --or-- Passenger Dash Fuse Box, rear gray 45 pin plug (J90), pin 20
Passenger Unlock Motor Blue Reverse Passenger Dash Fuse Box, rear white 43 pin plug (J91), pin 40
Factory Alarm Arm Tan (key lock) - Driver Kick, door harness, yellow 26 pin plug (J101), pin 10
Factory Alarm Disarm Blue (key unlock) Double - Driver Kick, door harness, yellow 26 pin plug (J101), pin 11
Factory Alarm Arm2 Tan (alternate location) - Body ECU on passenger dash fuse box, bottom black 30 pin plug, pin 28 Directwire
Factory Alarm Disarm2 Blue (alternate location) Double - Body ECU on passenger dash fuse box, bottom black 30 pin plug, pin 4 Directwire
Parking Lights Lavender/Green + Passenger Dash Fuse Box, white 43 pin plug (Q28), pin 30 Directwire
Parking Lights - Green - Headlight Switch, white 40 pin plug, pin 3
Hazards Lt. Blue - A/C Control Assembly, black 10 pin plug, pin 8
Turn Signal (Left) Tan (LF); Tan (LR) + Top of Driver Kick, white 63 pin plug (AJ1), pin 32 (LF); Passenger Kick, white 63 pin plug (JQ2), pin 48 (LR) Directwire
Turn Signal (Right) Lt. Blue (RF); Lt. Blue (RR) + Top of Passenger Kick, white 63 pin plug (AJ3), pin 27 (RF); Passenger Kick, white 63 pin plug (JQ2), pin 18 (RR)
Headlight Red - Headlight Switch, white 40 pin plug, pin 4
Headlight 2 Red (alternate location) - Body ECU on passenger dash fuse box, bottom black 30 pin plug, pin 26 Directwire
AutoLights Yellow Cut Headlight Switch, white 40 pin plug, pin 5
Reverse Light Blue + Top of Passenger Kick, white 63 pin plug (AJ3), pin 40
Reverse Light 2 Blue (alternate location) + Radio, gray 28 pin plug, pin 5
Left Front Door Trigger Lavender/Violet - Driver Kick, door harness, yellow 26 pin plug (J101), pin 24
Left Front Door Trigger 2 Lavender/Pink (alternate location) - Passenger Dash Fuse Box, white 43 pin plug (Q28), pin 3 Directwire
Right Front Door Trigger Lavender/Green - Passenger Dash Fuse Box, white 43 pin plug (Q28), pin 5 Directwire
Left Rear Door Trigger Lavender/White - Passenger Dash Fuse Box, white 43 pin plug (Q28), pin 28 Directwire
Right Rear Door Trigger Lavender/Tan - Passenger Dash Fuse Box, white 43 pin plug (Q28), pin 1 Directwire
Dome Light Pink - Body ECU on passenger dash fuse box, bottom black 30 pin plug, pin 5 Directwire
Trunk/Hatch Pin White (tailgate) - Passenger Dash Fuse Box, white 43 pin plug (Q28), pin 2 Directwire
Rear Glass Pin Red - Body ECU on passenger dash fuse box, top black 30 pin plug, pin 19 Directwire
Hood Pin White - N.C. Body ECU on passenger dash fuse box, bottom black 30 pin plug, pin 27 Directwire
Power Liftgate Black (tailgate) - Power Tailgate Opener Switch, gray 6 pin plug, pin 5 Directwire
Power Liftgate 2 Black (alternate location) - Body ECU on passenger dash fuse box, white 27 pin plug, pin 21 Directwire
Trunk/Hatch Release Pink (tailgate) (rear handle switch) - Certification ECU above driver kick, middle white 27 pin plug, pin 16 Directwire
Trunk Release Motor Blue - Pink (tailgate lock-unlock motor) (w/o power tailgate) Reverse Passenger Kick, harness to rear
Tachometer Red AC Certification ECU above driver kick, bottom white 30 pin plug, pin 15 Directwire
Tachometer 2 Yellow AC Camshaft Position Sensor, engine top rear, black 3 pin plug, pin 1
Clutch Pedal Pink + Certification ECU above driver kick, bottom white 30 pin plug, pin 3 Directwire
Clutch Pedal 2 Red (alternate location) + Clutch Start Switch, black 2 pin plug, pin 2
Fuel Pump Blue + High Above Passenger Kick, towards firewall, white 10 pin plug (AQ3), pin 7
Rear Defroster Black + Latched Passenger Dash Fuse Box, white 43 pin plug (Q28), pin 43
Mirror Defroster (LIN)
Wiper Deicer Gray - Latched Top of Passenger Kick, white 63 pin plug (AJ3), pin 17
Left Front Heated Seat (LIN)
Right Front Heated Seat (LIN)
Heated Steering Wheel (LIN)
Speed Sense Lt. Blue AC Certification ECU above driver kick, bottom white 30 pin plug, pin 13 Directwire
Speed Sense 2 Black (alternate location) AC Radio, gray 28 pin plug, pin 8
Brake Wire Green + Certification ECU above driver kick, bottom white 30 pin plug, pin 21 Directwire
Brake Wire 2 Lavender/Red (alternate location) + Brake Switch, white 7 pin plug, pin 3
Parking Brake Violet (EPB) - Top of Driver Kick, white 63 pin plug (AJ1), pin 44 Directwire
Parking Brake 2 Violet (alternate location) - Radio, gray 28 pin plug, pin 7
Horn Trigger Red - Horn Switch-Clock Spring, black 14 pin plug, pin 7
Horn Trigger 2 Gray (alternate location) - Passenger Dash Fuse Box, white 23 pin plug (A55), pin 11 Directwire
Horn - Factory Alarm Lt. Green - Passenger Dash Fuse Box, white 23 pin plug (A55), pin 4 Directwire
Wipers Green (LO); Red (HI) - Headlight Switch, white 40 pin plug, pin 26 (LO); pin 27 (HI)
Wipers Protection Black (ground) Cut Headlight Switch, white 40 pin plug, pin 33
All Windows Up-Down (use factory alarm arm-disarm)
Rear Sliding Window Open-Close Pink - Lt. Green (function with ignition on only) - Top of Passenger Kick, white 63 pin plug (AJ3), pins 35 - 37
Sun Roof (Open/Close) (use factory alarm arm-disarm)
Radio 12V Lavender/Lt. Blue + Radio, gray 28 pin plug, pin 4
Radio Ground Lavender/Brown - Radio, gray 28 pin plug, pin 1
Radio Ignition Gray + Radio, gray 28 pin plug, pin 16
Radio Illumination Green (parking lights); Violet (dimmer) +,- Radio, gray 28 pin plug, pin 25 (parking lights); pin 24 (dimmer)
Left Front Speaker (+/-) Lavender/Pink - Lavender/Violet or Red - White +,- Radio, black 10 pin plug, pins 2 - 7
Right Front Speaker (+/-) Lavender/Lt. Green - Lavender/Blue or Green - Black +,- Radio, black 10 pin plug, pins 1 - 6
Left Rear Speaker (+/-) Lavender/Black - Lavender/Tan or Black - Green +,- Radio, black 10 pin plug, pins 3 - 8
Right Rear Speaker (+/-) Lavender/Red - Lavender/White or White - Red +,- Radio, black 10 pin plug, pins 4 - 9
Left Front Speaker - With Amp Pink - Violet +,- Amplifier under driver seat, white 30 pin plug, pins 8 - 23
Right Front Speaker - With Amp Gray - Red +,- Amplifier under driver seat, white 30 pin plug, pins 13 - 28
Left Front Tweeter - With Amp Lt. Blue - Violet (tweeter); Black - Tan (midrange) +,- Amplifier under driver seat, white 30 pin plug, pins 14 - 29 (tweeter); pins 12 - 27 (midrange)
Right Front Tweeter - With Amp White - Pink (tweeter); Lt. Green - Blue (midrange) +,- Amplifier under driver seat, white 30 pin plug, pins 15 - 30 (tweeter); pins 9 - 24 (midrange)
Left Rear Speaker - With Amp Black - Violet +,- Amplifier under driver seat, white 30 pin plug, pins 10 - 25
Right Rear Speaker - With Amp Red - White +,- Amplifier under driver seat, white 30 pin plug, pins 11 - 26
Center Channel - With Amp Black - White +,- Amplifier under driver seat, white 30 pin plug, pins 7 - 22
Subwoofer - With Amp Brown - Green (coil 1); Black - Yellow (coil 2) +,- Amplifier under driver seat, white 30 pin plug, pins 6 - 21 (coil 1); pins 5 - 20 (coil 2)
Rearview Camera Video (no wire colors listed in service manual) +,- Radio, green 5 pin plug, pins 3 - 4
Item Size Depth Location
Headunit Irregular Center of Dash
Left Front Speaker 7.1 or 8 x 9 Left Front Door
Left Front Tweeter 1 (tweeter); 3.5 (midrange) Left Front Pillar (tweeter); Left Front Dash (midrange)
Right Front Speaker 7.1 or 8 x 9 Right Front Door
Right Front Tweeter 1 (tweeter); 3.5 (midrange) Right Front Pillar (tweeter); Right Front Dash (midrange)
Left Rear Speaker 6.3 or 5.9 Left Rear Door
Right Rear Speaker 6.3 or 5.9 Right Rear Door
Center Channel 3.8 x 7.3 Top Center of Dash
Subwoofer 10.4 Driver Rear Cabin WallGary Sather
If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Saturday, March 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
