Wire Diagram for 2003 PT Cruser
Memphis Belle
Posted: June 11, 2003 at 4:12 PM / IP Logged
I'm trying to find the wireing diagram for a 2003 PT Cruser with power windows power locks and the sentrey key anti theft deterrent system to install a Alarm with auto start. Could anyone help or point me in the right direction?
memphis belle
esmith69
Gold - Posts: 1,511
Posted: June 11, 2003 at 4:19 PM / IP Logged
This is for thr '02 but it might work for the '03....test all the wires before connecting though.
https://www.the12volt.com/installbay/get_topic.asp?fid=7&tid=7010&DIR=N
Ethan
Donate to the12volt.com
Platinum - Posts: 12,488
Posted: June 11, 2003 at 4:56 PM / IP Logged
12volts pink/black & red  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition blue  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ orange  +  ignition harness
Second Accessory BLACK/ white  +  ignition harness
Keysense lt. blue  -  ignition harness
Power Lock WHITE/ green  -  driver kick, door harness
Notes: Lock/arm requires a negative trigger thru a 3K (3000) ohm resistor. Unlock/disarm requires a negative trigger thru a 7.2K (7200) ohm resistor. Unlock requires a double pulse. MUST use relays.
Also found at the keyless entry module located above the radio in the center of the dash.
Power Unlock same wire as power lock
Lock Motor ORANGE / black  5wi driver kick, door harness
Notes: Also found at the keyless entry module located above the radio in the center of the dash.
Unlock Motor pink/black  5wi driver kick, door harness
Parking Lights+ BLACK / YELLOW  +  headlight switch
Parking Lights- N/A
Hazards same as turn signals
Turn Signal(L) lt. grn (F), dk. grn/red (R)  +  steering column
Turn Signal(R) tan (F), BROWN / red (R)  +  steering column
Reverse Light PURPLE / black  +
Door Trigger   -
Notes: The tan or tan/blue wire catches the driver door and is found in the driver kick panel. The blue/orange catches the three passenger doors and is found in the passenger kick panel. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin tan/black  -  driver kick, harness to rear
Hood Pin BROWN / tan  -  hood pin switch
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse the unlock wire
Tachometer BLACK/ gray  ac  ignition coil
Wait to start N/A
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake gray/black  -  parking brake switch
Horn Trigger BLACK/ red  -  steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Wire Diagram for 2003 PT Cruser -- posted image.
Immobilizer By Pass : Not Available
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
