Vampire Combo 1989 Chevy Suburban
jaggers814
Posted: March 26, 2002 at 9:16 PM / IP Logged
I just bought a Vampire remote start alarm combo and now I need some help installing it.  I have installed decks, speakers, subs and amps but have never done an alarm this complicated.  I need as much info as I can get, thanx.
 -Ryan
muscle cars
Posted: March 26, 2002 at 9:43 PM / IP Logged
Vampire remote start alarm combo:
Ok, help me help you:
Please supply the following information:
Year, Make and Model of the vehicle the system is being installed.
The model of the Vampire remote start alarm combo system that you purchase. Is the system new, used, or refurbished? Are all the parts included that are listed on the box? Is there a manual and insatll guide? how many remotes are included? How many buttons are onthe remotes?
Please give me the specifics on your vehicle:
Power windows?
Power door locks?
Power trunk release?
Automatic or manual transmission?
Convertible?
Do you currently have keyless entry?
Factory antitheft installed?
Remote Start?
2 door / 4 door?
Does your vehicle have an additional logo after the model name I.E.
XT, 442, GTO, LX, SL, ETC?
Who will be installing this device?
What options are you interested in installing?
70' 442 Rag Top
Moderator - Posts: 12,488
Posted: March 27, 2002 at 7:34 AM / IP Logged
Hey jaggers814 ;
The Vampire system that you have is an easy installation unit. Before you start to install try to use the tachless feature on the remote starter and if the system accepts the voltage from the Chevy, then you will not have to find yourself a tach wire.
 You can go to this link for the wiring information you need : https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1989-91&make=Chevrolet&model=Suburban&ID=17467&type=Alarm and this is a straight forward installation . The only problem you might have will be that the door lock and unlock on the Vampire system is only a negative output trigger, I'm not 100 % sure about the newer Vampire systems but the older ones only had a negative trigger output for the keyless entry. What you will need to do is to reverse the trigger out put of the Vampire alarm to ( + ) by hooking up 2 relays ( one for unlock and one for lock ) :
  • 86 + 87 pin : connect 12 volts constant
  • 85 pin : connect lock / unlock wire form Vampire alarm
  • 30 pin : goes to lock / unlock wire of the Chevy
Hope this helps you out and if you need some more help just post.
Best Regards,
jaggers814
Posted: March 27, 2002 at 10:13 PM / IP Logged
Muscle Cars:
I will be installing it on a 1989 Chevrolet Suburban 1500.  It has power windows, power locks, 4 doors, and an automatic transmission. My truck does not have a stock keyless entry, remote start or antitheft device.  The Vampire system I bought, has an alarm, keyless entry and remote start.  It came with two remotes that have 4 buttons each.  It did come with an install guide but it is very vague and does not help a begginer much.  All the parts listed on the box were included.  It is model 4040 Alarm/Starter, combo 4 button.  It also came with a pin to install that kill the engine if the hood is opened, but I am not sure how this hooks up.  I think you connect the wire into the bottom and when the hood is opened it grounds the system?  Does this sound right?
muscle cars
Posted: April 02, 2002 at 11:14 PM / IP Logged
The pin is a pin switch like the door switch that turn your light on when opened. You need to install that under the hood so the hood pushes it down when closed.
70' 442 Rag Top
Tuesday, October 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
