plymouth neon alarm
bobsonic
Posted: July 06, 2003 at 1:38 PM / IP Logged
I need help for connection the door pin of a neon 99 on a alarm. I try the connect on the yellow wire but the alarm didn't see when I open a door. The alarm is a marksman M7.
thank you
bobsonic
Platinum - Posts: 12,488
Posted: July 06, 2003 at 7:28 PM / IP Logged
DOOR TRIGGER|yellow/black        |-  |behind headlight swtch
bobsonic
Posted: July 07, 2003 at 3:11 PM / IP Logged
I will try it
bobsonic
Posted: July 12, 2003 at 11:50 AM / IP Logged
I try it but the alarm don't start when I open the door.
SkipMcGregor
Posted: July 13, 2003 at 1:45 AM / IP Logged
Are you going into the right wire, its not the one on the headlight switch, easy way to get to it, unscrew and pull out the fuse box the wire goes into the fuse box. Also the it is a NEGATIVE(-) trigger are you hooking the correct wire from the alarm?
huH!??!??!?
bobsonic
Posted: July 13, 2003 at 5:02 AM / IP Logged
I try on the fuse box where I have the timeout timer. on the alarm I have the correct wire I think. How can I test the wire on the alarm because I try to arm the alarm and put it on the chassis and the alarm didn't start.
SkipMcGregor
Posted: July 14, 2003 at 12:46 AM / IP Logged
check your diagram and make sure your using the (-) door trigger input, its the green wire on on H1 with most DEI products not sure about the marksman.
huH!??!??!?
bobsonic
Posted: July 15, 2003 at 3:58 PM / IP Logged
In the installation manual the wire for the negative door pin is green and I connect to yellow/black wire. When I open a door and try to arm, the alarm remind me a door is open and when I close the door and try to arm the alarm don't remind me a door is open. It's correct. But when I arm with all the doors close and I try to open a door, the alarm don't sound.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
