2003 Chevrolet 1500 Security Information
ivanp
Posted: July 11, 2003 at 10:11 PM / IP Logged
Can anyone please help me out w/ a 2003 Chevrolet 1500 Security Information sheet.?  I wish to install a Viper 790xv alarm to my Silverado.  Thank you for anyhelp you may give.
PS: If you have any other diagrams for this vehicle, please forward them to me.  That way i get tempted to add other neat things to my pickup.
Hello
Platinum - Posts: 12,488
Posted: July 19, 2003 at 12:19 AM / IP Logged
|              12V|red (x2)            |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink (12 awg)       |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|brown               |+  |ignition harness            |
|       POWER LOCK|use Directed module |   |                            |
|     POWER UNLOCK|part #456G *2       |   |                            |
|       LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door  |
|    DISARM DEFEAT|tan                 |   |pass. door module in door   |
| PARKING LIGHTS +|                    |   |                            |
| PARKING LIGHTS -|gray/black          |   |brown plug @ BCM *1         |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|gry/blk(L),blk/wht(R|-  |each door module in door *3 |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|                    |   |                            |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|lt. green           |-  |driver door module in door  |
|       TACHOMETER|NOT pnk, blk, or brn|   |any ignition coil           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|pink                |-  |steering column             |
|  LF WINDOW UP/DN|blue - brown        |A  |driver window motor         |
|  RF WINDOW UP/DN|blue - brown        |A  |passenger window motor      |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. The passlock II wire colors are yellow, black, and RED / white (not used).  *1 The BCM (Body Control Module) is under the driver side dash.  *2 If Directed module part #456G is not available, refer to directfax document #1601.  On base model trucks the lock wire is lt. blue (-) and unlock wire is white (-). They are in the lt. blue plug at the BCM.  *3 On base model trucks the door trigger wires are in the lt. blue plug at the BCM. On 4dr trucks the LR door trigger is lt. blue/black, and the RR is lt. GREEN/ black. They are in the purple plug at the BCM. Use all wires and diode isolate.
