2003 Eclipse V6 Manual, Neutral Switch
altima0235se
Posted: July 14, 2003 at 10:21 PM / IP Logged
Hi!
I am trying to locate the neutral switch signal on a 2003 Eclipse V6 with a Manual Transmission!
I am quite certain there is one, it is the only way to pervent the cruise from activating when switching it ON!
Any help is welcome!
catback
Silver - Posts: 703
Posted: July 17, 2003 at 4:59 PM / IP Logged
Manual Transmission's don't have a neutral safety switch. They have a clutch and brake switch to tell whether you have pushed either to turn off the cruise control. On newer cars the computer determines with switches or calculations what car the gear is in but still there is no neutral safety switch.
altima0235se
Posted: July 25, 2003 at 6:44 AM / IP Logged
The Altima 2002 with manual transmission as a Neutral Switch, it is used to prevent the the motor from goin wild in case you would place the transmission in neutral without touching the clutch of brake pedal!
So in this case, I used this signal for the remote starter safety!
