2002 mazda protege 5 info
slsknight
Posted: July 23, 2003 at 5:46 PM / IP Logged
hi. just wanted some info on a 2002 mazda protege 5. thanks.
apursell
Member - Posts: 22
Posted: July 30, 2003 at 12:31 AM / IP Logged
|              12V|BLACK/ white, black  |+  |ignition harness            |
|          STARTER|BLACK/ blue          |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|lt GREEN/ red *1     |-  |module high in driver kick  |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|red                 |   |door lock relays *2         |
|     UNLOCK MOTOR|blue                |   |door lock relays *2         |
|    DISARM DEFEAT|RED / black           |   |door lock relays *2         |
| PARKING LIGHTS +|lt GREEN/ black      |   |drivers kick panel          |
| PARKING LIGHTS -|brown               |   |headlight switch            |
|       HEADLIGHTS|RED / yellow          |-  |headlight switch            |
|     DOOR TRIGGER|BLACK/ blue          |-  |drivers kick panel          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / green           |-  |at light in trunk           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|PURPLE / white        |   |diagnostic connector *3     |
|      SPEED SENSE|orange or grn/red   |   |pin 58 of ECM *4            |
|       BRAKE WIRE|GREEN/ YELLOW        |+  |brake switch                |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|blu/wht(L),blu/red(H|+  |steering column             |
|  LF WINDOW UP/DN|RED / blk - yel/grn   |A  |drivers door switch         |
|  RF WINDOW UP/DN|grn/wht - lt grn/blk|A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|RED / grn - yel/red   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|blu/wht - grn/red   |A  |drivers switch or kick panel|
Notes:
*1 This is a one wire system, must use relays. Lock requires negative trigger through a 1.5K resistor, Unlock requires a negative trigger to the same wire.  *2 The door lock relays are located to the drivers side of the brake pedal.    *3 The diagnostic connector is in driver side rear corner of the engine compartment. Can also find tach in pin 48 of the ECM.  *4 The ECM is behind the passenger side of the dash.
slsknight
Posted: August 04, 2003 at 1:11 AM / IP Logged
thanks for the info. if anyone has more info please let me know. thanks agian. slsknight.
patmar
Copper - Posts: 69
Posted: August 23, 2003 at 10:09 PM / IP Logged
the tach found in back of cluster is PURPLE / white also found the parking brake in back
Thursday, May 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
