1992 Infiniti M30 Stereo Wiring Info
Hingding
Posted: July 24, 2003 at 12:49 PM / IP Logged
If anyone has any knowledge of the wiring in a 92 Infiniti m30, i would greatly appreciate it, cant find it anyone...Haynes doesnt even make a manual on the car. Thanks alot
ViperATC5
Copper - Posts: 202
Posted: July 24, 2003 at 4:04 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ purple        |+ |ignition harness            |
|          STARTER|BLACK / YELLOW        |+ |ignition harness            |
|   SECOND STARTER|BLACK/ red           |+ |ignition harness            |
|        IGNITION|WHITE/ black        |+ |ignition harness            |
|        ACCESSORY|blue               |+ |ignition harness            |
|       POWER LOCK|ORANGE / black        |F |drivers kick panel          |
|     POWER UNLOCK|same               |F |drivers kick panel          |
| PARKING LIGHTS +|GREEN / WHITE        |   |steering column             |
|       HEADLIGHTS|org/blu & RED / blk   |+ |left & right low beams      |
|     DOOR TRIGGER|BLACK/ red           |- |dkp harness to rear        |
| TRUNK/HATCH PIN|RED / white           |- |theft module in driver kick |
|        HOOD PIN|BLACK/ pink          |- |theft module in driver kick |
|TRNK/HTCH RELEASE|gray/red            |- |at switch                   |
| FCTRY ALARM ARM|yellow              |- |theft module in driver kick |
|FCTRY ALRM DISARM|lt. blue            |- |theft module in driver kick |
|       TACHOMETER|blue/orange        |   |ECM in pass. kick           |
|       BRAKE WIRE|GREEN/ YELLOW        |+ |at switch                   |
|     HORN TRIGGER|BLACK/ wht           |- |steering column             |
|           WIPERS|blu/orn and blue    |- |steering column             |
| LF WINDOW UP/DN|white - blue        |A |drivers door motor          |
| RF WINDOW UP/DN|brn/blk - grn/wht   |A |drivers door switch
