I need alarm wiring for 2001 dodge neon
marcomike
Posted: July 02, 2002 at 10:03 PM / IP Logged
Im going to install a remote start alarm and I need the wiring. I also wanted to know if that car has a immoblizer
Platinum - Posts: 12,488
Posted: July 03, 2002 at 5:01 AM / IP Logged
Dodge
Neon
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
BLUE
Ignition #2:
BLACK/ ORANGE
Ignition  #3:
N/A
Accessory:
BLACK/ WHITE
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK/ GRAY
AT COIL MODULE
Parking Lights:
BLACK / YELLOW (+)
STEERING COLUMN HARNESS
Headlights:
VIOLET/WHITE (+)
OEM Alarm  Disarm:
PINK/BLACK (+)
20-PIN CONN.IN DRIVER'S KICK PANEL****
OEM Alarm  Arm:
ORANGE / BLACK (+)
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped with the Sentry Key Immobilizer System.
Dodge
Neon
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
BLUE
Dome  Lights/Superv:
YELLOW (-)
LEFT OF STEERING COLUMN
OEM Horn:
BLACK/ RED (-)
Power  Lock:
LT. GREEN (-)
IN DRIVER'S KICK PANEL **
Power  Unlock:
LT. GREEN (-)
Trunk  Release:
LT. GREEN/ BLACK (+)
IN DRIVER'S KICK PANEL ***
Alarm  Input Wire:
YELLOW (-)
Notes:
** Single Wire Door Lock System. A Negative Pulse Through A 1,000 Ohm Resistor Locks the Doors, A Negative Pulse Through A 249 Ohm Resistor Unlocks The Doors. *** This Wire Is Also Found At the Keyless Entry Module Located At Top Center of Dashpanel. **** Also Part Of Single Wire System For Locks. A Negative Pulse Through 2.7 K-Ohm Resistor to Lt. Green Locks Wire Disarms the Alarm.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
