Anybody know if pwr windows in a...
civicboom
Posted: August 04, 2003 at 1:00 PM / IP Logged
power windows in a 95 eagle talon, are floating, normally grounded etc..
thanks ,
Montrealler
Copper - Posts: 155
Posted: August 09, 2003 at 11:21 AM / IP Logged
usually it's reversing polarity see ...
. https://www.the12volt.com/doorlocks/page3.asp#5w
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|BLACK/ red           |+ |ignition harness            |
|        IGNITION|BLACK/ white        |+ |ignition harness            |
|        ACCESSORY|blue/black          |+ |ignition harness            |
|       POWER LOCK|RED / blue            |- |*1                          |
|     POWER UNLOCK|BROWN / red           |- |*1                          |
|       LOCK MOTOR|blue/black          |   |drivers door harness        |
|     UNLOCK MOTOR|blue/red            |   |drivers door harness        |
|    DISARM DEFEAT|blue/red            |   |passengers door harness     |
| PARKING LIGHTS +|GREEN / WHITE        |   |in drivers kick             |
| PARKING LIGHTS -|GREEN / WHITE   22 awg|   |steering column *2          |
|       HEADLIGHTS|red                 |- |steering column             |
|     DOOR TRIGGER|RED / green           |- |in drivers kick *3          |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|RED / green           |- |driver kick panel *3        |
|        HOOD PIN|blue/black          |- |fuse box                    |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
| DISARM NO UNLOCK|GREEN / WHITE        |- |drivers door harness        |
|       TACHOMETER|white               |   |instument cluster or PCM *4 |
|      SPEED SENSE|yellow/white        |   |data link connector *5      |
|       BRAKE WIRE|GREEN / WHITE        |+ |brake switch               |
|     HORN TRIGGER|GREEN/ black        |- |steering column             |
|           WIPERS|blu/org(L),blu/blk(H|+ |steering column             |
| LF WINDOW UP/DN|grn/red - grn/black |A |in drivers door             |
| RF WINDOW UP/DN|brn/yel - grn / YELLOW|A |in drivers door or dkp      |
Notes:
*1 Located behind the glove box in a harness. To unlock only the drivers door on models with keyless entry. Use BROWN / blue negative (-) trigger at the relays behind the radio. *2 Found in a gray 20-pin connector. *3 To avoid the dome light delay use RED / white (-) at the door open indicator at the instrument cluster. The RED / white will also catch the rear hatch. *4 The PCM is located on the drivers side of the engine compartment or behind the center of the dash depending on motor.    *5 The data link connector is under the driver side dash. https://www.the12volt.com/doorlocks/page3.asp#5w
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
