2003 GMC Yukon Denali VSS
lazsae
Posted: August 16, 2003 at 2:11 PM / IP Logged
I have read other posts and looked on Rostra.com to find the VSS wire. The location that i have read about, a 10 pin connector near the firewall drivers side, does not have a GREEN / WHITE wire. It has a green solid, and a GREEN/ black. There are a few other small connectors in the same area, and none of them have a GREEN / WHITE. It would be great if someone knew where I can find this wire, even if I have to go straight to the tranny, any help would be greatly appreciated. Thanks
J. Lazarus
allstarauto
Posted: August 21, 2003 at 10:01 PM / IP Logged
Under the hood near the battery is where you can find the ECM. It is under a black cover near the fan. It is dark green and white at pin 50.
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
