F-150 firewall opening
pem2
Posted: November 10, 2003 at 6:40 AM / IP Logged
Hi,
I need to find an opening in 2003 Ford F150 firewall to route wires for a 2 way radio from battery to cab interior. Can anyone provide info and hopefully photo(s)
Paul
metz
Posted: November 10, 2003 at 1:57 PM / IP Logged
there is usually a rubber pop in grommet towards the center of the fire wall, then again it may only be on automatics
auex
Platinum - Posts: 5,041
Posted: November 10, 2003 at 6:11 PM / IP Logged
Why would you take power at the battery when you could take it from the ign harness? There is a grommet on the drivers side firewall near the brake booster.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
defective
Silver - Posts: 642
Posted: November 14, 2003 at 9:08 AM / IP Logged
also if your looking for a stealth wire run you can run through the black plastic harness channel at top of firewall.   Also you can drill beside the ecu right behind the battery, but be carefull $$$$$$$$$$
