wiring diagram-98 honda accord
nc_accord
Member - Posts: 8
Posted: July 28, 2002 at 1:28 PM / IP Logged
Does anyone have a stereo wiring diagram for a 98 honda Accord?
Platinum - Posts: 12,488
Posted: July 28, 2002 at 1:42 PM / IP Logged
Honda
Accord
1998-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition  #1:
BLACK / YELLOW
Ignition #2:
YELLOW
Ignition  #3:
Accessory:
WHITE/ BLACK
Brake  Light:
WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE
AT COIL MODULE
Parking Lights:
RED / BLACK
AT FUSE BLOCK ON DRIVER'S SIDE
Headlights:
OEM Alarm  Disarm:
BLUE
INSIDE OF DRIVER'S DOOR
OEM Alarm  Arm:
BLUE/WHITE
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This vehicle is equipped with a transponder immobilizer system;
Honda
Accord
1998-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BLACK/ WHITE (-)
4 PIN GREEN CONN. IN PASS FUSE BOX
OEM Horn:
BLUE/GREEN (-)
IN STEERING COLUMN HARNESS
Power  Lock:
GREEN/ RED (-)
IN TWO WIRE PLUG NEXT TO FUSE PANEL **
Power  Unlock:
BLACK/ WHITE (-)
Trunk  Release:
WHT/RED+
18 PIN GRAY CONN. ABOVE DRIVER'S KICK
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
** Negative Pulse Door Lock
nc_accord
Member - Posts: 8
Posted: July 29, 2002 at 8:48 AM / IP Logged
Do you have one for stereo??
Posted: July 29, 2002 at 10:38 AM / IP Logged
https://www.the12volt.com/installbay/stereodetail/1038.html
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
