Wiring Diagram: 1997 Ford Expedition
Welcome Guest :)
jscroggi
Member -
Posted: August 01, 2002 at 9:24 AM / IP Logged
I am installing an alarm/remote start for 1997 expedtion and need the wiring diagram
Platinum -
Posted: August 01, 2002 at 9:28 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | RED / L BLUE | IGNITION SWITCH HARNESS ** |
Ignition #1: | | | D BLUE/GREEN | IGNITION SWITCH HARNESS |
Ignition #2: | | | RED / BLACK | IGNITION SWITCH HARNESS |
Ignition #3: | | | GRAY / YELLOW | IGNITION SWITCH HARNESS |
Accessory: | | | BLACK/ L GREEN | IGNITION SWITCH HARNESS |
Brake Light: | | | L GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | WHITE/ PINK | AT POWERTRAIN CONTROL MODULE * |
Parking Lights: | | | BROWN (+) | AT HEADLIGHT SWITCH |
Headlights: | | | RED / YELLOW (+) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | | D GREEN/ PURPLE (-) | DRIVER KICK PANEL |
OEM Alarm Arm: | | | N/A | |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | * Powertrain Control Module (PCM) Located On Passenger Side Of Engine Compartment On Passenger Wheelwell. ** This Vehicle May Be Equipped With Ford's PATS Anti-Theft System. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | YELLOW (2), ORG/YEL & | L GREEN/ PURPLE (2) IGN. SW. HARNESS |
Starter Kill: | | | RED / L BLUE | IGNITION SWITCH HARNESS ** |
Ignition +12 Volts: | | | D BLUE/GREEN | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | BLACK/ L BLUE (+) | PASSENGER KICK PANEL |
OEM Horn: | | | D BLUE (-) | STEERING COLUMN HARNESS |
Power Lock: | | | PINK / YELLOW | DRIVER'S KICK PANEL *** |
Power Unlock: | | | PINK/L GREEN | DRIVER'S KICK PANEL *** |
Trunk Release: | | | N/A | |
Alarm Input Wire: | | | BLACK/ L BLUE (+) | PASSENGER KICK PANEL |
Notes: | | *** Without OEM Keyless Entry Reverse Polarity Door Lock With OEM Keyless Positive Pulse Door Lock |
Tuesday, April 7, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
