2003 Ford Focus Remote Start Wiring
n4tec
Member - Posts: 10
Posted: February 01, 2004 at 6:56 PM / IP Logged
Need remote start and bypass info for 2003 Ford focus. Thanks!!!
boomer_106
Silver - Posts: 710
Posted: February 02, 2004 at 6:27 PM / IP Logged
Ford
Focus
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
Gray/Black (+)
Ignition switch harness
Ignition  #1:
GREEN/ YELLOW (+)
Ignition switch harness*
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
Yellow (+)
Brake  Light:
Lt.GREEN/ Red (+)
Brake pedal switch
Tach  Signal:
BLACK/ Green (AC)
Ignition coil
Parking Lights:
Orange / YELLOW (+)
Headlight switch
Headlights:
N/A
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *This vehicle is equipped with Ford's PATS Anti-Theft security system. Use Universal Alarm Bypass Module part # 2x402 where X can be any number.
Ford
Focus
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Red (+)
Starter  Kill:
Gray/Black (+)
Ignition  +12 Volts:
GREEN/ YELLOW (+)
Dome  Lights/Superv:
BLACK/ Blue (-)
Low in the drivers kick panel area
OEM Horn:
BLACK/ Blue (-)
Steering column harness
Power  Lock:
BLACK/ Red (-)
Drivers kick panel
Power  Unlock:
BLACK / YELLOW (-)
Drivers kick panel
Trunk  Release:
BLACK / YELLOW (-)
Release switch or keyless entry module**
Alarm  Input Wire:
BLACK/ Blue (-)
Notes:
**The keyless entry module is located behind the glove box to the right side of the vehicle.
n4tec
Member - Posts: 10
Posted: February 02, 2004 at 7:13 PM / IP Logged
Thanks for the info again.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
