Ford Focus, 02 reg, wiring.
martinabramson
Posted: February 17, 2004 at 10:32 AM / IP Logged
02 model Ford Focus, turbo diesel, wiring to car alarm, central locking, indicators & interior light/direct earth contacts.
I have been involved with in-car security & hi-fi now for over 20 years.
boomer_106
Silver - Posts: 710
Posted: February 17, 2004 at 8:17 PM / IP Logged
Ford
Focus
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
GRAY/BLACK
IGNITION SWITCH HARNESS
Ignition  #1:
GREEN/ YELLOW
IGNITION SWTICH HARNESS*
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
YELLOW
Brake  Light:
GREEN/ RED (+)
AT SWITCH ABOVE PEDAL **
Tach  Signal:
BLACK/ LT. GREEN
AT COIL MODULE
Parking Lights:
ORANGE / YELLOW (+)
AT LIGHT SWITCH
Headlights:
OEM Alarm  Disarm:
BLUE/LIGHT GREEN
IN DRIVERS KICK PANEL
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped With Ford's Passive Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. ** This Wire Is Only Active When The Ignition Is On.
Ford
Focus
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
Starter  Kill:
GRAY/BLACK
Ignition  +12 Volts:
GREEN/ YELLOW
Dome  Lights/Superv:
OEM Horn:
Power  Lock:
BLACK/ RED (-)
DRIVER'S KICK IN DOOR BOOT ***
Power  Unlock:
BLACK / YELLOW (-)
Trunk  Release:
BLACK / YELLOW (-)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
Notes:
*** See Installation Note # 201 - Negative Pulse Door Lock Diagram.
