2002 Toyota Tacoma Wiring
aagsr90
Posted: March 08, 2004 at 9:18 PM / IP Logged
Looking for wiring info and speaker information.  Very hard to find anything.  Looking to install an alarm and stereo.  Any ideas are welcome.
boomer_106
Silver - Posts: 710
Posted: March 10, 2004 at 8:08 PM / IP Logged
Dont know about the stereo but, this should take care of the alarm.
Toyota
Tacoma
1996-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK
AT IGNITER ON PASSENGER WHEELWELL *
Parking Lights:
GREEN (+)
# PIN GRAY CONN. AT FUSE BLOCK **
Headlights:
RED / BLUE (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
IN SCHEAMTICS
OEM Alarm  Arm:
N/A
NO OEM ALARM PRESENT
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * BLACK Tach Wire Also Located In 26 Pin Connector Behind Glove Box.
Toyota
Tacoma
1996-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ RED & WHITE
Starter  Kill:
BLACK
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
BLACK/ WHITE (-)
2 PIN GRAY CONN. AT FUSE BLOCK **
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
RED / WHITE
# PIN CONN. IN DRIVER'S KICK ***
Power  Unlock:
RED / YELLOW
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
** Fuse Block Located In Driver Kick Panel. *** Child Safety Locks: RED / BLUE (-) In Same Connector As Door Lock Wires Above. See Note #209 - Toyota Child Safety Door Lock Diagram.
