04 Buick LeSabre Alarm Wiring
4mysecurity
Member - Posts: 22
Posted: March 11, 2004 at 10:55 AM / IP Logged
I need a wiring table (colors/locations) for installing an alarm system on a 2004 Buick LeSabre. Can anybody help? Thanks.
cbag1
Copper - Posts: 59
Posted: March 16, 2004 at 2:41 PM / IP Logged
12volts  orange (15A)   +   ignition harness
Starter  yellow   +   ignition harness
Ignition  pink   +   ignition harness
Power Lock  RED / black   -   driver lock switch in door
Notes: Can also use Directed 456A interface module.
Power Unlock  ORANGE / black   -   driver lock switch in door
Lock Motor  gray   5wi  driver door module in door
Unlock Motor  tan   5wi  driver door module in door
Disarm Defeat  tan   5wi  passenger door module in door
Parking Lights+  purple (L), BROWN / white (R)   +   rear fuse block, lt. gray plug
Notes: The rear fuse block is under the driver side of the rear seat.
Parking Lights-  BROWN / white   -   switch or DIM, brown plug, pin B3
Notes: The DIM (Dash Integration Module) is located just in front of the blower motor near the passenger kick.
Hazards  tan   -   switch or flasher module above DLC
Notes: The DLC (Data Link Connector) is under the driver side dash.
Turn Signal(L)  lt. blue (F), yellow (R)   +   flasher module above DLC
Turn Signal(R)  dk. blue (F), dk. green (R)   +   flasher module above DLC
Door Trigger  see notes   -   see notes
Notes: The driver door trigger wire is tan at the driver door module, and the other door triggers are dk. blue at their respective door modules. Use all four wires and diode isolate each.
Dome Supervision  gray   -   foot well courtesy lamp
Trunk/Hatch Pin  RED / black   -   RIM, black plug, pin B3
Notes: The RIM (Rear Integration Module) is located behind the rear seat back in the upper corner on the driver side.
Hood Pin  N/A
Trunk/Hatch Release  lt. blue   -   RIM, blue plug, pin B4
Power Sliding Door  N/A
Factory Alarm Arm  arms with lock
Factory Alarm Disarm  lt. green   -   driver door module in door
Disarm No Unlock  see factory alarm disarm
Tachometer  white   ac   instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is in the front driver side of the engine compartment inside the air cleaner box. The tach wire is in the clear plug, pin 8.
For tach can also use PURPLE / white or white at the ignition control module on the top front driver side of the engine.
Horn Trigger  black   -   column or DIM, gray plug, pin A6
Memory Seat 1  white   -   memory switch in door
Memory Seat 2  purple   -   memory switch in door
Memory Seat 3  N/A   -
 Immobilizer Bypass Module: Required: Yes Type: Passkey 3 Part #: 555G or 555U
Monday, November 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
