E36 323I 1997 wire diagram for facrory fi
Smokes
Posted: March 13, 2004 at 11:38 AM / IP Logged
im looking for a E36 1997 323I (UK) wire diagram for the factory fitted BMW alarm.
My factory fitted alarm packed up so i've purchased a new key less entry alarm system which comes with a full wire diagram. But i need to know wich wire does what from the plug which the old alarm was fitted to. If any can help me out would be great.
Smokes
cbag1
Copper - Posts: 59
Posted: March 16, 2004 at 2:26 PM / IP Logged
|              12V|                    |   |                            |
|          STARTER|BLACK / YELLOW        |   |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|         IGNITION|green               |   |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|violet              |   |ignition harness            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|pin 17              |+  |yel or pur plug, glove box  |
|     POWER UNLOCK|pin 4 or pin 19     |+  |yel or pur plug, glove box  |
|       LOCK MOTOR|                    |   |                            |
|     UNLOCK MOTOR|                    |   |                            |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|                    |   |                            |
| PARKING LIGHTS -|BROWN / blue          |   |hazard light switch         |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|BROWN / red           |-  |'A' pillar or interior light|
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|brn/vio or brn/wht  |   |at the bootlight            |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|black or blk/wht    |   |diagnostic plug under bonnet|
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|grn/red or blu/red  |   |brake pedal switch          |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|total close         |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|*1                  |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
*1 If cabriolet to open roof from channel output take low current negative to BLACK/ brown wire at switch in centre console and relay off channel output to positive to activate accessory wire on car at same time.
Smokes
Posted: March 16, 2004 at 4:21 PM / IP Logged
OOoooo thank you very much E36 323I 1997 wire diagram for facrory fi -- posted image.
Jag26
Posted: March 16, 2004 at 4:38 PM / IP Logged
I need wiring diagram for toyota matrix 2003.Im installing an alarm and remote strart.Any info will be highly appreciated!!
