93 buick regal power windows dead
Akeener
Member - Posts: 10
Posted: March 22, 2004 at 6:00 PM / IP Logged
I have posted this in the general discussion. I think this is a better place for it.  I need help with my power windows. the entire right side doesnt work.  the two wires going to the lift motor ohm out and the rest of the ones in the harness do too. Can anyone help?
Thank you
Adam
chriswallace187
Gold - Posts: 1,661
Posted: March 22, 2004 at 9:26 PM / IP Logged
what do you mean by the wires "ohm out"? To check the switch you'll need to test the voltage of the wires there, not the impedance. With the passenger window switch plugged in, meter the window motor leads. You should have 12 volts when the switch is pushed in one direction, and -12 volts when the switch is pushed the other way.
If you have that and it's not working, I would check the connection at the motor. If it's not showing 12 volts, check the connections at the driver's side switch.
Akeener
Member - Posts: 10
Posted: March 23, 2004 at 2:32 PM / IP Logged
thanks, i needed a little push.  I'll check the driver side
