1989 honda civic alarm wiring diagram
Wainstaller
Posted: April 22, 2004 at 2:00 PM / IP Logged
I need all the info I can get
ohms law
boomer_106
Silver - Posts: 710
Posted: April 23, 2004 at 6:15 AM / IP Logged
Honda
Civic
1988-1991
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK / YELLOW
Ignition #2:
YELLOW
Ignition  #3:
BLUE/WHITE
Accessory:
WHITE/ RED
Brake  Light:
GREEN / WHITE
(+) AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE
AT COIL
Parking Lights:
RED / GREEN
(+) AT HEADLIGHT SWITCH
Headlights:
RED / YELLOW (LO) OR
RED / BLUE (HI) (+) AT LIGHT SWITCH
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
Honda
Civic
1988-1991
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ BLACK AND
WHITE/ BLACK-IGNITION SWITCH HARNESS
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
GREEN/ RED
(-) WHITE CONNECTOR AT FUSE BOX
OEM Horn:
BLUE/RED
(-) STEERING COLUMN HARNESS
Power  Lock:
GREEN / WHITE
INSIDE OF DRIVER'S DOOR *
Power  Unlock:
GREEN/ RED
Trunk  Release:
N/A
Alarm  Input Wire:
GREEN/ RED
Notes:
* See Note #201 - Negative Pulse Door Lock Diagram.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
