Wiring diagram for 2004 Honda Civic
Welcome Guest :)
toyota_solara
Member -
Posted: April 24, 2004 at 11:30 AM / IP Logged
Hi, can somebody please help me with a wiring diagram for a 2004 Honda Civic.
boomer_106
Silver -
Posted: April 25, 2004 at 8:05 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | BLACK/ WHITE | IGNITION SWITCH HARNESS ** |
Ignition #1: | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Ignition #2: | | BLACK/ RED | IGNITION SWITCH HARNESS |
Ignition #3: | | N/A | |
Accessory: | | WHITE/ RED | IGNITION SWITCH HARNESS |
Brake Light: | | WHITE/ BLACK | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | BLUE | IN 2-PIN PLUG AT PASSENGER SIDE OF BATTERY |
Parking Lights: | | RED / BLACK (+) | AT BACK OF FUSE BOX |
Headlights: | | BLUE/RED (-) | AT HEADLIGHT SWITCH |
OEM Alarm Disarm: | | | |
OEM Alarm Arm: | | | |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * This Vehicle Is Equipped With A Transponder Type Engine Immobilizer Theft System. Use Universal Alarm Bypass Module part #2x402 where X can be any number. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | WHITE | IGNITION SWITCH HARNESS |
Starter Kill: | | BLACK/ WHITE | IGNITION SWITCH HARNESS ** |
Ignition +12 Volts: | | BLACK / YELLOW | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | SEE NOTE BELOW | |
OEM Horn: | | ORANGE (-) | STEERING COLUMN HARNESS |
Power Lock: | | WHITE/ BLUE (-) | GRAY PLUG ABOVE DRIVER'S KICK PANEL |
Power Unlock: | | WHITE/ GREEN (-) | GRAY PLUG ABOVE DRIVER'S KICK PANEL |
Trunk Release: | | N/A | |
Alarm Input Wire: | | SEE NOTE BELOW | |
Notes: | | ** The Driver's Door Trigger Is Green (-), Front Passenger Door Trigger Is Lt. GREEN/ Red (-), Rear Doors Trigger Is GREEN / WHITE (-). The Wires Are Found In The Alarm Plug In A Green Plug Above The Driver's Kick Panel. See Note#201 Negative trigger door locks |
Tuesday, April 28, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
