Need a couple wiring diagrams for 2002
Sp33dxquest
Posted: April 24, 2004 at 12:18 PM / IP Logged
Hi everybody,
I was wondering if anybody knows where I can find wiring diagrams for my sister's car ( 2002 Toyota MR2 Spyder ) as well as my  car ( 2002 Mazda Protege 5 ).  I am not sure which alarms we are going to install in the vehicles yet, but we are leaning towards the Viper 591XV and the Clifford Matrix RSX 3.5.
samtrey
Posted: May 03, 2004 at 9:06 AM / IP Logged
I have access to tech sheets that I find very helpful. I am not able to allow you access, but if you want, I will be able to print them and fax them to a fax number you give me. I have over 15 years experience installing car alarms and have many resources. I also have been installing the Viper systems since they were created. I would reccommend the viper systems. Let me know if you want my help.
Sam
rudbwoy69camaro
Silver - Posts: 350
Posted: May 06, 2004 at 1:04 AM / IP Logged
2002 Toyota MR2
ItemWire ColorPolarityWire Location
12Vwht/red & wht/blu+ignition harness
STARTERred+ignition harness
IGNITIONBLACK / YELLOW+ignition harness
ACCESSORYpink/blue+ignition harness
SECOND ACCESSORYRED / white+ignition harness
TACHOMETERwhitedrivers running board
POWER LOCKblue/white-drivers kick panel
POWER UNLOCKblue / YELLOW *1-drivers kick panel
PARKING LIGHTS +greendrivers kick panel
PARKING LIGHTS -RED / whitesteering column
DOOR TRIGGER*2-*2
HEADLIGHTSRED / white-steering column
WIPERSblu/blk & blu/red+steering column
LF WINDOW UP/DNred - greenAdrivers kick panel
RF WINDOW UP/DNred - greenApassengers kick panel
LR WINDOW UP/DNnone
RR WINDOW UP/DNnone
TRUNK/HATCH PINnone
HOOD PINnone
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMnone
FACTORY ALARM DISARMnone
HORN TRIGGERWHITE/ red-steering column
BRAKE WIREGREEN / WHITE+at brake switch
LOCK MOTORblue/reddrivers kick panel
UNLOCK MOTORblue/blackdrivers kick panel
DISARM DEFEATno progressive unlck
DISARM NO UNLOCKnone
DOME SUPERVISIONuse door trigger
SPEED SENSEPURPLE / whitedrivers running board
SUN ROOF OPEN/CLOSEnone
SUN ROOF LIMITnone
LF SPEAKERpink - purpleradio or speaker
RF SPEAKERgreen - blueradio or speaker
LR SPEAKERnone
RR SPEAKERnone
RADIO 12Vblue / YELLOW+radio
RADIO GROUNDbrown-radio
RADIO SWITCHgray+radio
RADIO ILLUMINATEgreen+radio
POWER ANTENNAblack+radio
Notes:NOTE: Some models have an immobilizer system that needs to be bypassed during remote start. Use DEI module 555F or 555U to bypass. *1 Requires a double pulse for unlock. Using the same color wire in the passengers kick only requires a single pulse. *2 Drivers door is red or RED / white in the drivers kick panel. Passenger door trigger is RED / white in the passenger kick panel. Use both wires and diode isolate each
rudbwoy69camaro
Silver - Posts: 350
Posted: May 06, 2004 at 1:05 AM / IP Logged
2002 Mazda Protege5
12VBLACK/ white, black+ignition harness
STARTERBLACK/ blue+ignition harness
IGNITIONblue+ignition harness
ACCESSORYBLACK/ white+ignition harness
SECOND ACCESSORYBLACK/ red+ignition harness
TACHOMETERPURPLE / whitediagnostic connector *3
POWER LOCKlt GREEN/ red *1-module high in driver kick
POWER UNLOCKsame wire
PARKING LIGHTS +lt GREEN/ blackdrivers kick panel
PARKING LIGHTS -brownheadlight switch
DOOR TRIGGERBLACK/ blue-drivers kick panel
HEADLIGHTSRED / yellow-headlight switch
WIPERSblu/wht(L),blu/red(H+steering column
LF WINDOW UP/DNRED / blk - yel/grnAdrivers door switch
RF WINDOW UP/DNgrn/wht - lt grn/blkAdrivers switch or kick panel
LR WINDOW UP/DNRED / grn - yel/redAdrivers switch or kick panel
RR WINDOW UP/DNblu/wht - grn/redAdrivers switch or kick panel
TRUNK/HATCH PINRED / green-at light in trunk
HOOD PINnone
FACTORY ALARM ARM
HORN TRIGGERBLACK/ red-steering column
BRAKE WIREGREEN/ YELLOW+brake switch
LOCK MOTORreddoor lock relays *2
UNLOCK MOTORbluedoor lock relays *2
DISARM DEFEATRED / blackdoor lock relays *2
SPEED SENSEorange or grn/redpin 58 of ECM *4
SUN ROOF LIMITnone
LF SPEAKERnone
RF SPEAKERnone
LR SPEAKERnone
RR SPEAKERnone
RADIO 12Vnone
RADIO GROUNDnone
RADIO SWITCHnone
RADIO ILLUMINATEnone
POWER ANTENNAnone
Notes:*1 This is a one wire system, must use relays. Lock requires negative trigger through a 1.5K resistor, Unlock requires a negative trigger to the same wire. *2 The door lock relays are located to the drivers side of the brake pedal. *3 The diagnostic connector is in driver side rear corner of the engine compartment. Can also find tach in pin 48 of the ECM. *4 The ECM is behind the passenger side of the dash.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
