Need Wiring Diagram for 99 Honda Passport
jsuarez041
Posted: May 24, 2004 at 6:29 PM / IP Logged
I anyone could help me I would greatly appreciate it. I need the wiring diagram for a 1999 Honda Passport or Isuzu Rodeo.
splking
boomer_106
Silver - Posts: 710
Posted: May 24, 2004 at 8:24 PM / IP Logged
Honda
Passport
1998-2001
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/ WHITE
IGNTION SWITCH HARNESS
Ignition #1:
BLACK / YELLOW
IGNITION SWITCH HARNESS
Ignition #2:
BLACK/ RED
Ignition #3:
N/A
Accessory:
BLUE
Brake Light:
RED
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK/ RED
AT COIL #1 ON DRIVER FRONT ENGINE *
Parking Lights:
GREEN/ RED (+)
AT FUSE BOX
Headlights:
OEM Alarm Disarm:
YELLOW/BLUE (-)
WHITE PLUG IN DRIVER'S KICK PANEL
OEM Alarm Arm:
PURPLE (-)
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Wire Can Also Be Found At PCM Located At Front Of Center Console.
Honda
Passport
1998-2001
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE/ BLACK & WHITE
Starter Kill:
BLACK/ WHITE
Ignition +12 Volts:
BLACK / YELLOW
Dome Lights/Superv:
RED / GREEN (-)
DRIVER'S KICK PANEL
OEM Horn:
DK. GREEN (-)
IN STEERING COLUMN HARNESS
Power Lock:
LT. GREEN/ RED (-)
DRIVER'S KICK PANEL **
Power Unlock:
RED / DK. BLUE (-)
Trunk Release:
N/A
Alarm Input Wire:
RED / GREEN (-)
DRIVER'S KICK PANEL
Notes:
** See Note #201 - Negative Pulse Door Lock Diagram.
Isuzu
Rodeo
1998-2002
Function
Vehicle Color
Location
Start:
BLACK/ WHITE
Ignition #1:
BLACK / YELLOW
Ignition #2:
BLACK/ RED
Ignition #3:
N/A
Accessory:
BLUE
Brake Light:
RED
Tach Signal:
BLACK/ RED
AT CYLINDER #1 COIL PACK DR. SIDE ENG.
Parking Lights:
GREEN/ PINK (-)
4 PIN CONN. TO LEFT OF STEERING COLUMN
Headlights:
OEM Alarm Disarm:
YELLOW/BLUE (-)
OEM Alarm Arm:
PURPLE (-)
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
Isuzu
Rodeo
1998-2002
Function
Vehicle Color
Location
Constant +12 Volts:
Starter Kill:
BLACK/ WHITE
Ignition +12 Volts:
BLACK / YELLOW
Dome Lights/Superv:
RED / GREEN (-)
DRIVER'S KICK PANEL
OEM Horn:
DK. GREEN (-)
IN AIR BAG HARNESS
Power Lock:
LT. GREEN/ RED (-)
Power Unlock:
RED / DK. BLUE (-)
Trunk Release:
RED / BLUE(-)
AT SWITCH
Alarm Input Wire:
RED / GREEN (-)
DRIVER'S KICK PANEL
Notes:
* See Note #201 - Negative Pulse Door Lock Diagram. ** For Disarm, Yellow/Blue Wire Must Receive A Negative Pulse Simultaneously With The Unlock Pulse. For Arm, The Purple Wire Must Receive A Negative Pulse Simultaneously With The Lock Pulse. Split Off Of The Lock And Unlock Wires Respectively And Diode Isolate. Alarm Disarms Through Ignition For Remote Start.
