2003 Nissan Maxima wiring diagram
antisoc247
Posted: September 01, 2002 at 9:23 PM / IP Logged
Hello,
Does any1 have this? I am trying to install a Viper remote starter...
TIA....
cpgoose
Gold - Posts: 1,098
Posted: September 06, 2002 at 7:28 AM / IP Logged
Man, that's a toughie.  Maybe someone knows who has one of those fancy cds that has every car.  You might be able to use 2002 or 2001, but maybe not.
Nissan
Maxima
2002
Remote Starter  Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Start:
Yellow
BLACK/ WHITE & BLACK/ BLUE
IGNITION SWITCH HARNESS *, **
Ignition  #1:
Blue
BLACK/ RED (SMALLER)
Ignition #2:
Green
RED / YELLOW
Ignition  #3:
Wht/Blk
N/A
Accessory:
White
WHITE/ BLUE
Brake  Light:
Orange
RED / GREEN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
Green
WHITE/ GREEN
IN WHITE PLUG BEHIND INSTRUMENT CLUSTER ***
Parking Lights:
Yellow
RED / BLUE (+)
DRIVER'S KICK PANEL *****
Headlights:
Yellow
GREEN/ YELLOW & BLUE/BLACK (-)
AT HEADLIGHT SWITCH ****
OEM Alarm  Disarm:
Brn/Wht
DISARMS WITH UNLOCK
OEM Alarm  Arm:
n/a
ARMS WITH LOCKS
Diesel  Glow Plug:
RED / Black
Clutch  Bypass Wire:
n/a
Notes:
 * This Vehicle Is Equipped With A Transponder Type Engine Immobilizer Theft System. See Installation Note #144 - Bypassing Transponder Theft System. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold; See Note #251 - Nissan Starter Wires Diagram. *** DO NOT START ENGINE WITH INSTRUMENT CLUSTER UPLUGGED!
Nissan
Maxima
2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Constant  +12 Volts:
Red
GREEN
Starter  Kill:
Vlt or Wht
Ignition  +12 Volts:
Orange
Dome  Lights/Superv:
Brown
SEE NOTE BELOW ******
OEM Horn:
Blue
GREEN / WHITE (-)
STEERING COLUMN HARNESS
Power  Lock:
Wht/Red
ORANGE / BLACK (-)
DRIVER'S DOOR MODULE *******
Power  Unlock:
Yel/Red
ORANGE / BLUE (-)
Trunk  Release:
Grn/Wht
Alarm  Input Wire:
R/W or Gy/Bk
Notes:
g A Key In The Driver's Door.
