wiring diagram for 1990 integra gs(alarm)
teg_pd
Posted: September 02, 2002 at 7:08 PM / IP Logged
i need a list of wire identification so that i can install my alarm. if you know where i can find one or if you have one please let me know.
much appreciated!
peter d
Platinum - Posts: 12,488
Posted: September 02, 2002 at 10:28 PM / IP Logged
|              12V|white or wht/blk    |+  |ign harness or fusebox      |
|          STARTER|BLACK/ white         |+  |ign harness or fusebox      |
|         IGNITION|BLACK / YELLOW        |+  |ign harness or fusebox      |
|  SECOND IGNITION|blue/white          |+  |ign harness or fusebox      |
|        ACCESSORY|yellow              |+  |ign harness or fusebox      |
|       POWER LOCK|GREEN / WHITE         |-  |either kick panel *1        |
|     POWER UNLOCK|GREEN/ red           |-  |same                        |
| PARKING LIGHTS +|RED / green           |   |steering column             |
|       HEADLIGHTS|RED / yellow          |+  |steering column             |
|     DOOR TRIGGER|GREEN/ red *2        |-  |dr kick panel/fusebox       |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|GREEN/ black         |-  |dr kick panel/fusebox       |
|TRNK/HTCH RELEASE|manual              |   |                            |
|       TACHOMETER|blue                |   |distributor                 |
|      SPEED SENSE|yellow/red          |   |instrument cluster          |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|blue/red *3         |-  |steering column             |
|           WIPERS|blue and blu/yel    |-  |at switch                   |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/grn - blu/yel   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|green - grn/yel     |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|yel/grn - yellow    |A  |in drivers door or dkp      |
|        RADIO 12V|WHITE/ blue          |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|yellow/white        |+  |radio                       |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                       |
Notes:
*1 Easier to locate at passenger kick panel.  On drivers side, wires are located high in kick panel.  *2 Looks like a 14 awg. wire,  but is mostly insulation.  *3 High-current ground.  Use a relay when interfacing with this circuit.
