Wiring Diagram needed
Welcome Guest :)
hot_shot_guy123
Copper -
Posted: April 18, 2002 at 4:55 AM / IP Logged
I need one for a 2002 chevy cavalier thanks!
Platinum -
Posted: April 18, 2002 at 5:40 AM / IP Logged
Chevrolet | Cavalier | 2000-2002 |
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | YELLOW | IGNITION SWITCH HARNESS * |
Ignition #1: | | | PINK | IGNITION SWITCH HARNESS |
Ignition #2: | | | N/A | |
Ignition #3: | | | N/A | |
Accessory: | | | ORANGE | IGNITION SWITCH HARNESS |
Brake Light: | | | WHITE | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | | |
Parking Lights: | | | DK. BROWN (+) | AT REAR OF LIGHT SWITCH |
Headlights: | | | | |
OEM Alarm Disarm: | | | DISARMS WHEN VEHICLE IS | STARTED EITHER BY THE KEY OR REMOTELY |
OEM Alarm Arm: | | | N/A | |
Diesel Glow Plug: | | | N/A | |
Clutch Bypass Wire: | | n/a | | |
Notes: | | * This vehicle is equipped with GM's PASSLOCK II Anti-Theft system. See Note #113 - General Motors PASSLOCK II Bypass Diagram. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | RED | IGNITION SWITCH HARNESS |
Starter Kill: | | | YELLOW | IGNITION SWITCH HARNESS * |
Ignition +12 Volts: | | | PINK | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | L GRN/BLK & L BLUE (-) | AT BCM UNDER LEFT SIDE OF DASH *** |
OEM Horn: | | | BLACK (-) | STEERING COLUMN HARNESS |
Power Lock: | | | LT. BLUE | AT BCM UNDER LEFT SIDE OF DASH ** |
Power Unlock: | | | WHITE | AT BCM UNDER LEFT SIDE OF DASH ** |
Trunk Release: | | | | |
Alarm Input Wire: | | | L GRN/BLK & L BLUE (-) | AT BCM UNDER LEFT SIDE OF DASH *** |
Notes: | | ** Without OEM Keyless, Reverse Polarity Door Lock Diagram. With OEM Keyless, - Positive Pulse Door Lock Diagram. *** L GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. |
Sunday, April 19, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
